LB7 with ZF6 into 84 crew cab Chevy
jbmatth
Oct 20, 2015
North Central Ok.
For some reason I can't view the photos even when logged in. On another note I have my lift installed now so give me a call when you are ready to swap the cabs over.
JB
bigdisplay442
Jan 21, 2017
I've got an 1988 c/c dually 2wd that i just started my Duramax conversion on.
It appears in your core support pic that you mounted the oem intercooler behind the core support.
If so, did this still allow room for the radiator And factory cooling fan to fit as well.?
Thanks, chres
Tsmyth
47
Yes, I used oem intercooler and radiator. There was plenty of room for the fan.
Tsmyth
47
I've had the truck together for a couple weeks now, it runs remarkably well, it will break the tires loose in 5th gear. I have the trans pulled right now to send the clutch back to south bend......
Tsmyth
47
I haven’t posted here in a while, I’m on a swap page on fb quite a bit, if anyone is interested in it, it’s Gm Squarebody Duramax Swap on Facebook. At any rate, since my last post on here, I put the clutch back in, south bend was great with reworking it...quick turn around time and cost like 100 dollars I believe. Anyways, the Dana 70 that was in the truck....well, it was ruined not long after the clutch was reinstalled, too many 4th gear pulls ripped the ring gear teeth off of it....so I put a 14 bolt in it out of a 94 Chevy dually, seems to be holding up nicely. I was also running the clutch master cylinder from a square body, it ended up being a no go, had to modify the firewall and pedal to accept a duramax master cylinder.
