The truck is a manual truck, but wa a mechanical clutch. I've robbed the hydraulics from another truck, pedals and all for this swap. 65 dollars for full assembly at the junk yard. Had to remove it myself. Tonight, I finished modification of motor mounts (if what I've done works, these mount can be purchased fairly cheap) I also installed a new throw out bearing/slave cylinder. Now the motor and trans are mated back together. Then I started welding on the cab at the seams since I cut the "cab lip" off for clearance.
