LB7 with ZF6 into 84 crew cab Chevy
Tsmyth
47
I don't have a picture of the clutch master cylinder but the one I am using is stock for an 80s model Chevrolet.
Tsmyth
47
Okay so it's been a while since I actually posted some good progress, so here it goes, here is the engine crossmember.....I'm sure some of my work will look horrible to most of you....
Tsmyth
47
Engine crossmember tied to frame engine mount.
Tsmyth
47
Transfer case linkage and linkage mounting.
Tsmyth
47
Transmission and transfer case shifters in the cab, keeping it "period correct".
Tsmyth
47
Recently I've been working on mounting the radiator and the inner cooler on the core support, it has been pretty difficult but I think I've got it. Here is a picture of it almost done. I've also removed the bed and started cleaning and painting the frame.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Looks great bud, be proud of your work! Your making me excited to get going on mine:thumb:
jbmatth
Oct 20, 2015
North Central Ok.
Looks good man, I'll have so swing by sometime after work and check it out. I like the way you made the cross members, what thickness tubing did you make them out of?
JB
Tsmyth
47
Sorry there haven't been any updates, I'm at a stopping point right now, I'm waiting on my wiring harness.
Tsmyth
47
Just a quick update, everything on the fuel system is complete. I built a steel tank that mounts in stock location on the drivers side. It holds 29 gallons. It was a tight fit and I had to trim some of the cab. With the tank mounted, I plumbed in all new lines, to a fass 150 and then lines to the stock fuel cooler, from there I ran lines to the engine. Will post pics as soon as I get new ones, I lost my old phone in the river on memorial weekend. Still waiting for my harness, literally can't do anything else until I get it.
Tsmyth
47
Here is a pic of the outside of my frame rail where the fass 150 is mounted, picture is horrible, you can kinda see my tank in the background.
