Johnny's Truck is Running !!!!!!!!!!
To bann JOhhny untill he builds his motor
  • Total voters
    59
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
fabbing is so funny deciding this way or this way .
so many ways to skin the cat .
Drvr side mount is giving me some trouble , need to tie in ear mount area .
Nothing to bolt to . Has to come from 4 bolt pad behind and below .
Pass side has a few bolt holes on face of block Im going to use with bracket .
Been also thinking about complete cross member under pan between mounts .
Chewing on alot of idea's at the moment .
Doing some measuring right now to see how much exactly the mounts went down and out . Should be 1/8 down and 1/8 out on each side with plate at 45 deg . If I guess right . Need to machine pads on back of mounts down some .
Back at it , smoke break is over . :D
670
since you got a nice abundance of 1/4" plate.
cut a secone peice out drill holes in it. then weld the holes and outer edges. the will give you a 1/2" plate and stronger as well.
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
Im getting there on something pretty strong .
Just been a little hard with just a sawzaw a drill and a grinder .
Ive have some welding to do now . I made some sweet brackets and Im thinking about doing what you said and doubling them up .
Just trying to do it all right the first time . Drvrs side mount is being a pain .
I think ive got something that is strong . Will post some pics later .
Did another plate below other one that stubs up to front of ear mounts on both sides .
Pass side much stronger than drvrs side . Working on that now .
Johnny
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
Ok I made some more plates go under others and give me something to tie ear mounts into .
Still crude looking and need to be tuned up .
Passenger side has tie in on upper plate , making it really secure .
Drvers side is a pain , nothing to bolt to . I made a nice up bracket and am copying it now to add one behind front one . Then tie them together and do some boxing in and gussets on the whole thing to beef it up .
No laughing , Im doing the best I can with what I have . I wont run it all if it doesnt look like it will hold up .
Im keeping the faith in my abilities .
View attachment 4316View attachment 4317View attachment 4318View attachment 4319
Alright going to get back to it . Time to start welding and make some headway .
Im going with the " I Think I Can , I Think I Can .. . . Attitude "
Turbotug
BEER SLAYER
Sep 3, 2006
1,019
46
Phoenix
The boxing/gusseting is where this will be won or lost!
Keep to it!
BigRedHD
SO CAL DIESEL TRUCKS
May 27, 2008
672
41
INGLEWOOD,CA
ok i made some more plates go under others and give me something to tie ear mounts into .
No laughing , im doing the best i can with what i have . I wont run it all if it doesnt look like it will hold up .
alright going to get back to it . Time to start welding and make some headway .
Im going with the " i think i can , i think i can .. . . Attitude "
thats the spirit we got faith in your abilities
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
Ok after thinking more I doubled everything up . 2 Lower plate stacked and 2 uprights .
Now I will start tacking and bracing .
Adam (Malibu) came by and we went on got more sawzaw blades .
Cutting Grinding for another couple hours , Ive got all my pieces .
Well one more .... always that last one to do .
I think this is pretty strong . Need to drill some holes in plates to weld to each other still .
View attachment 4325View attachment 4326View attachment 4327View attachment 4328View attachment 4329
Now I just need to decide where to box in and gussett for ultimate strength .
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
I can go o McFaddendales and get some better ones .
These were what I got my hands on . Was thinking the same thing .
There is 9 bolts into the block both sides . 18 total holding mounts to block .
I think they are strong enough . But easily replaced .
Just need to weld and gussett now .
Johnny
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Nice work guys:cool: Johnny you gonna patent these babys:D
Just a thought on the bolts,Think of what you would rather break
I admire your move forward attitude:rockon:
And tell Nucklenuts to stay away from your womens coolers!
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
So , have any of you looked under your hoods to see if your trucks have the ear mounts on you blocks .
Look for the bosses also , 2 of them on each side of front cylinder walls .
2 that are bigger around pad and larger thread .
All would not be used on 2500 and you should be able to be seen easy .
Just wondering how common these commercial blocks are or if all 05 and later have these castings .
