LLY: Is my Water Pump gone?
paint94979
Beer Nazi
Sep 18, 2006
11,715
Hard to tell from these pictures but i lost about an inch or so of coolant and now this morning i look under the truck to see this?
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
hope thats all it is, mine is leaking from that exact same spot, not quite that bad yet. i am not looking forward to replacing it.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
mine has done that twice now over a year or so and goes away for mounths :confused: , so i am just going to fix it once it does it frequently .
BigNuggz
Oct 19, 2008
9
How much hp did you pick up with your modded pump? You went from 107 to 113? R u running 4.10s? THats wack your waterpump is weeping
paint94979
Beer Nazi
Sep 18, 2006
11,715
I went from 108 to 113.9 and there is still more mph left I had lots of problems with the 60's I'd say I gained over 100hp
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
wow I must drive more than most people. My truck is a 2005 and I have 107,000 miles on it..
FWIW I just replaced my water pump too, it was the factory original though.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Lots of guys gone through on the llys Mine has been good for a long time 100 000.....Knock on wood
Why did I say that:rolleyes:
I wouldnt frett about changing it, its a couple hour job:)
1,848
Yeah, w/p is probably bad, although if I were paint, Id check that bypass hose above the balancer first.
w/p replacement isnt too bad a job. Hell, if Ben can do one without breaking anything, anyone can do it! :rofl:
j/k Ben :)
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
j/k Ben :)
Good point.....I had to change that on the side of the highway and it wasnt fun.
Duramax_ak-47
Mar 14, 2009
Kansas
I had the same problem with my 01 but it was not the water pump. yours might be different, since its newer. the line that comes from above the water pump had an O-ring that was trashed, causing it to leak.
