Installing a electric water pump
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
Great thread! Great info!
How much is a new oem water pump btw? Thinking this might be the way to go when the time comes.... just over 100k now so hopefully not for some time but ya never know :(
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
Thanks Dustin for the information. This has lead me to a better decision on water pump replacement. Hope to see you enter the next Diesel Challenge 2011.
You can't have the same truck and same driver in the Diesel Power Challenge more than once - unless they win and are coming back to defend their title. More Diesel Addiction trucks will be entered for next year though.:thumb:
Advance Auto pumps are around $110 - we haven't had any issues with trucks with stock motors and I wouldn't recommend an electric pump for everyone that has to replace the water pump. Typically they go out when the seal fails and they start leaking out the weep hole - throw in a normal replacement and it'll be fine for another 100K miles. The ones from NAPA don't mesh right with the cam gear and whine but other than that I haven't had or heard of many problems with the parts store pumps. If you get to the power level that you start breaking pumps (typically the press fit of the gear or impeller to the shaft) then you might want to consider electric. Mine broke the press fit so I welded it, broke the weld so I welded it better, then started breaking the shafts themselves - after 12 pumps in 2 months it was time to give up and go electric.
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
maybe we can ship mine from Hawaii back here for the DPC :happy2:
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
I know this is totally unrelated to the pumps but I see both the LB7's and LLY's used a 1 3/4" electric pump. Any idea if the LBZ lower rad hose is the same I.D.? Mine measured best I could tell around 2 1/4 - 2 3/16 O.D.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
its not the same, LBZ is bigger, but its too dark to go out and measure it right now
FWIW: I ordered a Stewart pump from Jegs Aug 2nd, and its still backordered with no ETA. i might cancel the order and try mezierre.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I believe its 2.5 or 2 .250
Jegs was the last place I tried when ordering the pump and they only had 3 left in stock
When I spoke with the rep from S/W he said they really dropped the ball
Mezierre is probably a better pump just like the way the SW IN/OUT is byt nothing a lil creative thinking cant handle:)
I know 3 guys that are trying to get there hands on a SW and feel the same as you:(
I do love haveing a electric pump....Ted and I swapped a pump the other day on a 700 hp truck and there was vitually nothing left of the impeller
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
you could just use a alluminum or stainless swedge
maine04max
Dec 11, 2008
1,009
looks like I may have a water pump issue now . may try one of these inline pumps , just hope i can get one quickly events coming up next weekend .
maine04max
Dec 11, 2008
1,009
thanks Tim :thumb: turns out it was definitely a pump issue, impeller side broke free even with a tack weld on it
maine04max
Dec 11, 2008
1,009
I didnt even try after talking to them . we have diesel drags this friday, sat and sunday we have sand drags , radar and block pulls in embden me that i really want to attend so we are welding a new one for now and im having my welder block off the one that broke so i can do an electric pump later this fall
othrgrl
Mar 10, 2008
2,151
Wilmington NC
I tried every type of welding and even had a groove machined in the ends of the shaft and impeller and gear to lay a nice weld into. I even machined 1/4 of the fins off to lighten the impeller and make it grab less water. But for a temporary fix I can see doing it. As far as welding the broken one up all you need is 3 freeze plugs and some green lok-tite.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I heard SW has gone to bat and made a bunch of pumps since the demand has recently gone up.
Ive never been happpier with a mod than with this one! I hot lapped my truck 3 times runninng low 10s and with 1 electic fan it got to a max of 82c this is with McRats T stats though
As far as running it on a DD I cant comment,But any truck running over 700 HP you need to do this IMO
I swapped a water pump on a truck that has 650 to 800 hp the other day.....he had less than 1000 miles sicne upgrading and his water pump was TOAST!!! worst iv ever seen!!
Guys realize this is a problom with our trucks! and there is a simple fix
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
X2! I can pull my truck, pull it off the track and shut it off, leave the electric pump and fans going and it will go from 200 or so, to below 160 in just a few minutes. We just modified my stock thermostats so they always flow a little bit of water when the pumps are on. The only problem i had, is my relays for my pumps and fans got wet and failed last week and i didnt know it, the truck got hot a blew a coolant line friday night. So from here out, i check the coolant flow, and fans before i pull.
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
Determined the LBZ has a 2 3/8" o.d hose so that would make it a 2" i.d. (3/16 wall) Problem is summit nor jegs has one. Is there a possibility it's just not online? Where else could I find one?
