Hasn't been one run on a duramax or Cummins to my knowledge. Borg warner doesn't have the turbine housings really available to run them on a diesel yet, so HTT is making their own stainless housings to fit. It is a very cool turbo from what I've seen. Uses a ball bearing cartridge that is water cooled and they use gamma-ti turbine wheels which are super light, so rotating weight is down improving spool up. Borg also has some cool options in them like a built in blowoff valve in the compressor housing, per tapped for a shaft speed sensor and some stuff for better gate control.
There only two options that will really work on the diesels. A 62mm and a 68mm
Sent from my XT907
