Highest HP achieved
Mpsoldier
That just happened!
Mar 10, 2010
646
In my House
whats the highest hp achieved on stock motors. :thumb:
ALSO Who tuned it and i know they wont live long just interested in knowing.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Its really not "how high", its for "how long".
Im sure a stock engine would survive/live to make a couple runs at 1000hp+. But then probably blow up on the 3rd or 4th run....
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
The crazy thing is our motors are built soooooo much heavier duty than a gasser but there are a bunch of 5.3 ls motors living at 1000-1200hp and our barely live at 600hp. I guess that really proves that Torque is what destroys a motor:mad:
super diesel
<<<< Under Pressure
I think there has been a few in the 700-800 range but didn't live very long at those levels.:(
Correct. When there REALLY running at that level they last a sort time. At about 850-875hp or so from what I've seen at the track, they blow parts right away in most cases. One I saw made one good run and the next run it was KABLUWEE. And we were picking up parts.
5,611
Put our crank next a to a big block chevy crank. You will be un-pleasantly surprised :D
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
Never really seen a big block up close only small blocks. Is a BBC Crank bigger than ours? What i was getting at is i know the parts in a dmax are way bigger than that of a 5.3 ls and they are standing upto 1200hp but not much torque being put out
5,611
Well you would think a diesel would have a bigger crank than a gasser right? Our cranks are smaller compared to a bbc but bigger than a sbc. Torque is the killer but our inner parts are no where near as beefy as i once thought
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
Yes James i assumed our cranks would be bigger than a BBC i never thought about it that way really i just always thought dmax internals were way beefier than a sbc and never really compared them to a bbc.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
so any numbers come on i no mark is at 765 on stock lbz the c10 dmax is at 760 lly stock any lb7 numbers or lmm
I hit 815 hp ( trap speed / weight ) on stock LB7 and close to 50 or so pass's at 700 ish , bent a rod just after the 815 pass ( 11.0 @ 124 ) . I think weight of truck is extremely relevant to the topic , my weight at the time was between 6400 -6300 lbs .
Mpsoldier
That just happened!
Mar 10, 2010
646
In my House
1,000HP. I tuned it. I'll tune yours for $10,000. No warranty.
sweet cant wait when can you do it lol and the motor is going into a 68 camaro just putting ideas out there. total weight should be less than 4000 aim high get lower i be happy going to be like mike wood with a bose head set on bc i will run out of time prior to leaving to afgan to finish everything else.:thumb:
