Help with the truck that no one can tune
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
Look at MAF and Duration here... Also take note of the IAT... Its 154 degrees..
B1185 and B1184 are pulling fuel from B1177(Torque Based Fuel)
I'm thinking that all the hours that Tony and others have spent tuning are around a sensor or mechanical issue. 154 degrees is almost to the max of the table values. It does seem to go up and down a bit in the log, but only a few degrees.. If the sensor is damaged it still could fail to a value that is legit in terms of diagnostics, but not conducive to fueling and making power.
Long and short of it. The owner/builder need to get the truck in the tuners hands, whoever that may be and I would bet they find out what is wrong quickly.
Brayden
Hi All, Ross here, thought I'd better let everyone know about our involvement with this. Without repeating the same story as previous posts, essentially we were asked to look in to why this particular truck was going in to reduced power.
Through some investigation and some internal file modifying and a few shots in the dark we had it to the point where it was not setting DTC's, but, it was still going in to limp mode. It was at that stage I had to say to Tony that I didn't know what direction to take as far as tuning goes...How can an ECM decide to take serious action like reduced power and not set any DTC? To solve the problem we needed a lead to go by, with no DTC to chase, there's no lead.
From our perspective we also asked this question, since the LMM tuning came out there has been numerous trucks built with bigger than normal modifications, as far as we knew all problems that have been encountered with these builds had been solvable with what is in the current tuning release. So it was not really about 'we have better things to do', it was questioning why this particular truck was different to all others before it.
And this gets back to the fact that there was no DTC being set, how can EFILive add tables that some claim to be missing when we don't even know why the ECM was doing what it was doing? So our door is not closed, without a lead we are looking a 'needle in a haystack' type proposition on a single vehicle where many 1,000's have been tuned before it.
Cheers,
Ross
GMC_2002_Dmax
The Still Master
Cheers,
Ross
That's exactly why I walked away.......no boost=no codes...........it is what it is.
:thumb:
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
Come on.. You're a more intelligent person than that.. At least you seemed to be while we were drinking beer gettting Nitrous bottles filled at the challenge.
If this is the truck I'm thinking of, the builder has called everyone in the country.. I talked to him and to me it sounded like (log showed it) was an IAT problem. If the IAT2 is damaged the truck won't fuel. Has anyone actually checked to see if that sensor isn't damaged?
Brayden
I'm not a tunaahh :D if a part goes on my truck and I cant make it work right through tuning, it comes off. If the tuner can't make it work, I trust him, because I'm not smarter than him until I decide to prove him wrong. Sorry, didnt mean any offense by calling your cat stupid in this guys case.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
I'm just joking around Dave :hug:
And so am I. No worries. I went through hell and back trying to get my truck to run right. I wanted to burn it. So many people tried to tune my truck over the internet and it never worked. Tony was actually my first choice for tuning but when I called him he declined to do it because he hadn't tuned enough LMM"s to feel comfortable to do it. This was 3 years ago mind you. I respected that and figured we didn't need 3 trucks in my class using the same tuner anyways. I think Ross explained things pretty well. Just sucks for the OP when he has all this money into a bad ass truck and it won't run right.
Duraeater6.7
Jun 14, 2012
53
I think that's the problem....... I must have left a shop rag and my 12mm deep well socket in the intake...... Sorry Trey .... Hehehehe
Duraeater6.7
Jun 14, 2012
53
I worked along side Trey on this georgia build, it's not mechanical, I've/we "Trey and I" have spent hours looking for something mechanical. It's not mechanical!!
I was also along side Tony in GEORGIA and yes he came here sat in the seat and live tuned the truck!!! The truck ran fantastic all afternoon, returned the truck to the customer an hour later the famous 0299 underboost code was back!!
Not trying to start a s*** storm but why doesnt someone besides Tony address that there is a problem and get together and solve it instead of this "oh I can fix it send it to me" BS
bluessmax
Tabasco Injected!
Nov 4, 2010
1,143
Lake Charles, la
I guess my post and request are ignored.... good luck everyone. Let's have a shit throwing contest and bash other tuners and never get it fixed instead. Trey, bring us the truck and well fix it.
Plain and simple
Lol...wow what a shitstorm over this.
blackdirtymax
Apr 15, 2010
825
augusta, ga
Plain and simple
Lol that's a little bit of a ride Kory lol I'll do it If you want me to , lmao
bluessmax
Tabasco Injected!
Nov 4, 2010
1,143
Lake Charles, la
I'll take care of accommodations... we have about 20 trucks at the shop to turn out by next tuesday because me and Brad are going to nuevo vallarta mexico on Wednesday so there will be no time before then, but the week after.. any time will be fine.
BUST'EM 504
1,047
Tell your pop to get the gooseneck right and I will bring it down. Hope you get it figured it out. Carry on
mplv
Nov 20, 2009
70
Just to clarify my truck is not the one Trey has the same issues with. I am game for whatever.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
Brayden
Good points, is this the only log you have? I would be curious if every log taken showing the reduced power issue shows the same high IAT and stupid pw and timing values...
Edit: Just seems too obvious/unlikely that on two different trucks that are setups extremely similar with dozens of logs taken and multiple sets of eyes logging and tuning them, that one or two critical sensors would be to blame. I'm not disagreeing that it may be mechanical, just way to hard to not give those who have spent so much time diagnosing these trucks the benefit of the doubt that they would've not noticed IAT staying nearly maxed out on every log.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Ill say it again....if someone can get me some serious/detailed logs, voltages, temps, conditions, and then put a tick mark exactly where it commands REP on the log, I will look into making something to fix this.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Kinda off topic, sorry. But how do you know when a code sets while watching a log? It would have really helped figure out some past issues.
