Headers vs Manifolds
Mikey
Drag Racer
Jun 13, 2009
560
3
Funny thing to say after one comment after your posts ''you guys'' .
Maybe you haven't done your home work ? Gasoline or Diesel exhaust energy doesn't matter it works the same.
As soon as possible? It should be as smooth as possible.
Even consecutive pulsation, selecting the correct material (inconel vs stainless vs mild steel which all have different thermal transfer rates) , conducting the correct practices (header wrap or thermal coatings) .
Smaller tubing diameter (entirely depends on the type of power you want to make) and longer lengths are better for a lower rpm engine.
Also I completely disagree on response any changes in induction and exhaust require tuning to optimize power and from my experience more available power have come from proper headers vs manifold.
I agree
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Me too. There is a real log style header in the makes with each runner the same length. Much like the normal shorty headers you'd find on a belair or something like that. But they have 2 different collectors. 2 ports into each one. I don't know what the final collector to uppipe setup is going to look like as they haven't finished yet. But I bought manifolds because I have heard some log style manifolds have cracked. And I just cracked a uppipe... Bellow none the less, but I choice to stay with a thick material manifold.
MAXX IT OUT
Neglected
Mar 1, 2013
1,781
Des Moines, Iowa
I argree on what your saying for an naturally aspirated engine.....so running a log style header is not really worth it, unless it is a completely custom and high powered set up.
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
Sorry to be off topic but I feel that my topic pertains to this topic,
Is the purpose of a divided exhaust housing vs an undivided exhaust housing for a turbine to help with the exhaust pulsations depending on the cylinder firing pattern?
Also, would a remote turbo mount not function properly if the exhaust pipes are not the same length from the passenger and driver side banks?
S Phinney
4,008
Quncy, Fl
The two main points that some if you are missing is what Rick is trying to say. One us exhaust energy and thermal energy is required in a turbo setup for optimal performance. Too long of piping and you loose thermo energy to the pint that you hurt performance. That is why you have short tubes on turbo diesel applications. The second pint is there us pressure on each side of the system in a turbo application so thermo energy and flow volumes become more important. A gasser that is naturally aspirated isn't as froguvi g as a diesel that is turbo charged. Gassers do not have near the thermal energy as a diesel or the cylinder pressures that create that energy.
Sent from my XT1080 using Tapatalk
Cknight199
Aug 23, 2012
1,827
X2 otherwise we could mount turbos in the bed :D would make fabrication a lot easier
RickDLance
1,276
14
Also remember we do not have the 600-6000 rpm usable range either. I've spent lots of money and lots of time playing with the different styles. The turbocharged diesel engine IS a different animal. :)
Magnus
Jun 22, 2013
144
I see all the time where people argue about whether heat or flow drives a turbo, and I think the world would be a better place if people fighting like school kids used proper school kid terminology. Everyone go google enthalpy. It's roughly defined as a unitless convenience property expressing the sum of inertial and thermal energy in a moving fluid. Flow energy and heat both matter. Note I said flow energy not just velocity, because restricting the volume to increase velocity can be idiotic and counterproductive.
The only way to tell true performance results is experimentation and probably nobody has seen more custom exhaust setups than Rick.:thumb:
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
All I know is that I run Rick's log headers and the noise that my truck makes tickles my undercarriage. That is all.
Mikey
Drag Racer
Jun 13, 2009
560
3
Longer stroke and higher compression makes up the difference
MAXX IT OUT
Neglected
Mar 1, 2013
1,781
Des Moines, Iowa
Lower RPM's, higher exhaust temps, and more exhaust gases you could add to your list....our turbos work more in the bottom of the RPM range then to top unlike a gases engine, which need a minimum of like 3 or 4k before they will start to spool.
Cknight199
Aug 23, 2012
1,827
Just solidifying something a read... From what I have understood, a turbo works off both flow and heat, with heat increasing flow because as something heats it expands, making more flow through the charger, hence the turbo farther away from the heat source will not have as much flow through it as a turbo right off the manifold. Am I correct? This is for my own benefit.
Dave c
Jul 7, 2013
294
This is not entirely true. Gasser engines produce way more cylinder psi than diesel and thermal energy. shrink the head ports, RPM and exhaust pipe size and bet the gaser could spool up instant.
Just a FYI the avg pro stock gas engine puts out 4000PSI cylinder psi
Pro mod gas engine produces between 6-7000 psi
Top alcohol is 8-9000 PSI
Top fuel is as high as 15,000 psi.
Now factor in the bore size at the listed PSI and its astounding. Very few diesels are even close to the gasser pro mod PSI level.
S Phinney
4,008
Quncy, Fl
Thermal energy of gasoline is not as high as diesel. Compression on gasoline engines is not as high as diesels. Gasoline engines have a predetermined thermo capability as gas and air are mixed when it enters the cylinder and can;t change after that. Diesel engines fuel enter without the air and can be changed during the combustion process. on a gasoline engine the cylinder pressures go down exponentially as the piston moves down from TDC. On a diesel cylinder pressures do not go down exponentially since you have the ability to add more fuel during the process. This is the reason why a gas engine does not generate the heat a diesel does nor does it have the thermal energy. A comparable size gas engine does not close to making the torque a diesel does. I am not the smartest guy in the world but these items are why the demands between the two engines are so different.:thumb:
Magnus
Jun 22, 2013
144
Sweet 8lb baby Jesus is nobody here an engineer? I already posted saying at least google enthalpy (unit less convenience property that combines inertial energy of the flow with thermal energy).
Don't even try to lump any type of alcohol engines in as "gassers"
A diesel converted to run on CNG is closer to a gasoline engine than a methanol swilling monster is.
Sorry for going way off topic but this thread is getting absurd.
