Having trouble keeping trannys in it, other than that ok i guess..LOL..
Will he have it at the test and tune pull?
Never Satisfied, You are the only one then that I know of that's leaking. At least I'm glad of that. Let me know. My offer to fix it still stands.
How is Corey's truck doing?
Here is my first feeble attempt at the slip fit. The discoloration on the pipe is from heating it with a rusebud while bolted on to the motor. Just wanted to see what it would do with heat. Hopefully next week we'll see how it seals while on a running motor.
Thanks Brayden, we'll do.
Thank you Rick. It wont be long and I will probably give up on them. Then I will get in contact with you.
This is not the only thing I have had bad customer service on with MDP.
Thanks
This design will only move in and out correct? Don't you need it to move in every direction? A design like the 3 piece would be good if you can make it work, it will move every direction.
You wanna try a slip joint in it instead?
My current up pipes have the flex down low on the ps and midway on the ds. Here's some pics. Also I've snapped a couple of pics of a "normal" cut in the flex.
