11.34 at 121 walked it sideways in the right lane. Had been running left and 6th is grinding every run
12.3 at 118 ground 2 gears 1.69 60 foot cold trans
11.219 at 122 1.660 60 foot ground 6th
Dropping air running more
Don’t go too low or the center of the tire will cup in on launch and you will loose grip
I think Mark Nixon still has that ZF for sale over at CompD if it comes to that.
Well piss, so now what, new trans or fix that one?
Sounds like what used to happen to me with my Mustang going from 2-3. Fine under normal driving, but under power would jam up.
Hopefully it'll be a "simple" fix that wont cost you an arm and a leg.
When you're breaking new ground, you always the first to find the weak points and the first to fix them.
Well right when we got it launching good, could have used a small drop in pressure in back again. 6th gear ground every run and now doesn't exist anymore. But probably 10 passes at 750 hp and didn't break it other than 6th. Cut a best of 1.57 60 foot still slightly spinning the backs.
Sweet!!! Get any vids??
Sweet man! How much does it cost to build a zf6 compared to a Allison?
Jake has them, we have alot of videos
