Fully deleted lmm smoke at idle
jeremycoleman727
Apr 24, 2017
The smell comes from the low sulfur diesel run some lucas fuel treatment and it will stop for a short time
Sent from my VS995 using Tapatalk
J_Stone06
Wasn't me...🥴
Oct 13, 2012
347
3
Nowhere, KS
I've have a light puff at cold start. Can be a little hazy until I'm warmed up a little bit. Had another guy tell me he runs a qt of trans fluid in every tank of fuel to help with keeping his injectors cleaned/lubed, especially running low sulfur fuel.
Idahodmax
Dec 22, 2015
51
I know its been awhile, but alot has gone on, haha.. but ya i alwats ran sea foam, and usually howes winter anti gel. My main reason for bringing this up to begin with is, when i sit at a stop or let the motor warm it hazes, but i can smell it in the cab through the vent, in starting to think my sinister diesel egr delete blocker plate has some leak by..
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
Is your grid heater deleted?
Idahodmax
Dec 22, 2015
51
I dont think so, i did the sinister diesel egr delete kit, so the blocker plates and exhaust up pipe mount and coolant lines rerouted
monster50iii
338
Check balance rates at startup. You could have a weak glow plug. I found I soon to be bad glow plig this way. You'll see +6 to +8mm3 on a cylinder with a bad glow plug, and the longer it runs that number will slowly go down to normal once cylinder temps increase. This causes smoke at idle of course.
