The fuel inlet temperature has a significant influence on the performance levels
of internal combustion engines, and this is particularly true for
diesel engines. As a result, many passenger car manufacturers
take this into account and incorporate a fuel temperature control
system into their high-performance, latest-generation diesels.
HSDI passenger cars are utilized around the world, often operating in extremely high and low ambient temperatures. As a consequence, the engine's power and torque levels can be reduced to such an extent that the machine's performance is severely limited.
Decisive for these requirements are the results of optimizing air intake, engine breathing, fuel injection and combustion chamber geometry, all of which affect the combustion process. Diesel
engine development concentrates on such aspects as varying the shape of the combustion
chamber and the size of the piston bowl in conjunction with precise control of
the fuel injection timing, pressure and quantity. Particular progress has been achieved
with electronically controlled engines, and, in the process of minimising gaseous emissions,
it has been possible to maximize performance levels.
The conflict of interest which engine developers are often faced with is how to improve
one particular criterion without negatively affecting others. An efficient combustion
process requires a homogeneous mixing of the charge air and the injected
fuel. This process is assisted if the diesel fuel is heated.
A higher fuel temperature improves the diesel fuel's fluidity (kinetic viscosity),
which is important for the injection process and the mixing characteristics. An improved
kinetic viscosity lends itself to an optimum formation of the injection spray,
which in turn leads to reduced gaseous emissions, significantly influenced by the
evaporation properties of the injected diesel spray.
With a starting point of 100 % power with the reference fuel temperature
of 45 °C, without cooling, without heating, HSDI engine performance values decrease
or increase, as the fuel temperature rises or falls respectively.
Of particular interest is the initial fuel heating of 10 °C from 45 °C to 55 °C,
Which leads to a significant performance reduction of 7.5 %. A drop in the diesel fuel inlet temperature from 45 °C to 25 °C results in a performance increase of 5 %, and raising the fuel temperature from 45 °C to 80 °C leads to a performance reduction of 14 %.
Performance continuously falls by 19 % with rising fuel temperature
(from 25 °C to 80 °C), but the fuel consumption remains constant throughout.
The injected fuel volume falls with rising temperature, which is the direct result of a decreasing diesel fuel density with rising temperature. The lowest fuel consumption occurrs at a fuel temperature of 45 °C. As mentioned above, this is the reference temperature
used in the diesel engine industry for establishing combustion processes.
The injected energy quantity continually falls with rising fuel temperature, from 25 °C to 80 °C.
The specific fuel consumption also stays relatively constant, the best point being at
25 °C fuel temperature and increasing insignificantly up to 45 °C. Compared with
the absolute fuel consumption, the lowest calculated specific fuel consumption occurs
at 25 °C, as a result of the power increase of 5 %.
HSDI engine fuel temperature tests demonstrate clearly that
changing the fuel inlet temperature from the standard temperature of 45 °C has a significant
effect on performance levels. From 45 °C to 80 °C, the power drops by 14 %, and
when the fuel is cooled from 45 °C down to 25 °C, performance increases by up to 5 %.
With this fundamental characteristic (increasing fuel temperature results in decreasing
engine performance) fuel consumption does not decrease at the same rate, but remains virtually constant. The reduction in engine performance with increasing fuel temperature is predominantly
due to the accompanying decrease in fuel density, which in turn results in reduced injected
fuel quantities and therefore energy content. The combustion process in the engine clearly is less efficient at higher fuel inlet fuel temperatures.
State-of-the-art HSDI passenger car engines are developed with a standard reference
fuel inlet temperature of 45 °C.
I found this on a TDI forum browsing around the other day and it's what got me thinking more about fuel temps
