Found the noise in my engine
dmaxlover
Mar 17, 2007
453
WI
Not sure if you're being sarcastic, or just don't know about engines, but for those readers who really don't know:
Nope, being serious. The indentation look pretty deep in the pics, but it's hard to tell how deep they really are. I realize there is expansion in the pistons, and they rock pretty damn good in the bores, but the clearance must of been very close to start with.
Mick, from what you can tell, do you know what the piston protrusion is now, and how thick the head gaskets were while clamped.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
The problem is getting the piston square in the hole and guessing at how much piston material has been beat off. It may take a bit to get the answer.
9,905
151
I usually just measure at the wristpin to get as accurate a number as I can. I don't know what GM's reccomended procedure is for checking this.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
When Mick measured like this suggestion, the smallest measurement was .020" but, this was on the edge with the most head to piston damage the biggest was greater but by how much depended on pressure applied. The gasket measured after removal and uncompressed but previously installed of course was .03?" can't recall for sure and failed to write it down. Sorry for the vague info but more detail soon.
9,905
151
The spec eludes me for stock protrusion, but I believe that .020" is WAY too much.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Here is why it's hard to get an accurate protrusion measurement. Granted skirt measurements should measure .035" more. Still I think the block is no longer usable unless a .090" piston is available. :eek:
Umm.. the blow by was horrible.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Going off memory,
I like to run flush, but I believe the factory spec is .010" above.
4.030" is the factory dia, but pistons should be measured at the bottom of the skirt, it's larger. A .010" overbore will actually cleanup quite a bit of damage. He'll have to bore the worst cylinder first to see what piston options he has.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Going off memory,
I see, most likely is. I was measuring one of Kevin's stock pistons and got the .035" difference in piston top to skirt difference. Again, he we was rough measuring, nothing in stone as you know.
13,751
821
Going off memory, max protrusion for C grade gaskets is .0148" or something like that. There's an overbore/decked block head gasket that can be used if you have more protrusion, but I don't think it is rated for that much protrusion.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Pat are you saying a .060" piston may repair this depending on the largest hole? Really though, it would be best for us to provide better measurements with the proper mic.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Pistons
I run mine out .026 with the decked/overboard gasket and it would just kiss the head shifting at 4800 rpm. I did change it when I changed the head gaskets and dropped the piston .010 when it went back together. Alot of things happen at rpm that wouldn't turning it over on the stand. I have allways found a motor to make more power the closer you run the piston to the head. Jeff
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
What about skirt to cylinder wall clearance? .030 seems to be a big load on the rings not counting the obvious.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Piston to wall
I run .010 on the pistons. I think(fwiw) that to many people try and run these motors to tight. With the power that most are trying to make you need some clearance on the bearings and some room for the piston's to grow. It doesn't really matter gas or diesel when the power goes up the clearance needs to follow suite. If anyone thinks there going to get 100k on a race motor there not being relistic. Big power is hard on parts. I'm not bragging but my motor has been very reliable and I think i'm making ok power. I race every weekend there is someplace to race and I never give it any slack. Jeff
Trippin
SoCal Diesel
Aug 10, 2006
663
Mike/Mick,
Piston skirt to cylinder wall clearance should be around .006 on that Mahle forged piston when it went together.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Mike/Mick,
Thanks Guy.
I wonder about the " at a glance " clearance. Would this help explain why the exhaust side of the piston top hit the head and sorta rolled " if you will " into the other side top to head?
Trippin
SoCal Diesel
Aug 10, 2006
663
Thanks Guy.
Yes.
