Forged Vs. Billet Rods
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
What kind of money will a guy have wrapped up in a set of those Simon?
I think the bamboo rods range from 125.00 up to 600:joker:
As for the connecting rods they are around 3000.00 ish ( The NORM )
These guys run a pretty small shop and are IMO all very knowlegible and helpfull and eager to help
C.A.P
Feb 16, 2008
103
I thought Carillos were billet rods as well. I haven't kept up with them since I went with the Crower.
Rods are not the area of concern for me, pistons maybee but , So far I have not heard a ton of failures with the bowls cut ! ...:confused:Where is the wood KNOCK KNOCK !
Trippin
SoCal Diesel
Aug 10, 2006
663
Crower, Cunningham, and most others are billet. Billet is easy, buy a piece of material and start machining.
Carrillo are forged. Now we are talking about molten metal squished into a die. Forged is stronger.
Next is the "I" beam vs "H" beam discussion.
Both Audi and Peugot started with a blank sheet of paper for their Diesel racing programs. Both chose forged "H" beam.
Things that make you go hmmmmmmm.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
37
Central Coast, Cali
www.sikdmax.com
Thanks for the info Guy. Do you plan on carrying several brands/styles of rods/pistons or are you going to stick with 1? Any idea of timeframe for pricing/website updates?
On the other hand, that 7.1L Kit is looking enticing :D
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
At this point in time, I think your wasting your money on forgings. Unless I'm missing something (which I could be) we are not at the power levels to require a forged rod.
We have customers that want to over build all the time.... Diesel engines are a bit different than rocket engines or gas turbines, but overbuilding isnt always the best answer. If you have plenty of money then forged should be fine, but if you want to save every penny you can and not skemp on quality then "good" billet rods should serve you fine.
I think the crank would fail before a good billet rod would...
ripmf666
15,123
14
47
Wentzville Mo
Thanks Guy,
H beam hold up better then I beams but i might be wroung since Isais billet was better lol
Trippin
SoCal Diesel
Aug 10, 2006
663
I carry both the Crower and Carrillo brand, so you always have a choice. Coming soon are the Howard Rods, which are an "I" beam forging with the FPO or Forced Pin Oiling option for about $2850.
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
Do you like the forced pin oiling option?:) I think it would be a bennifit
but i dont have the experiance that you do! I still think every lil thing helps
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
The crank?:eek:
I read of a place that will build custom cranks,but never heard of enough failures,That would concern me?
I know cranks have failed but it was because of other probloms Not the crank?
what do you know? or what have you read? C'mon spill the beans:D
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
one thing I have read is that you should take the wieght of the connecting rod into consideration
IMO you go with Tripp you let him do the research and just pull out the visa:D
personally I would of done this, But i bought a lot of stuff from a fellow member:) And yet Guy has still helped me!! He is top notch IMO
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
A computer model of mine says its the next weakest piece, but I dont know if I trust my modeling skills yet... Still on the learning curve.
Trippin
SoCal Diesel
Aug 10, 2006
663
I like the FPO. Some of the high HP engines have started to flatten the bushing in the small end. Perhaps this extra lube will fix this issue. Time will tell.
If it doesn't I'll just get rid of the bushing and go with a DLC pin.
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
i would agree... once we get a proven piston the wont crack/rip i think the crank/block is the next weak link
given if the mains stay put and not allow the crank to walk
Do you not think the main studs from ARP are enough Adam?
Block could be a issue,Since GM decided to build a stonger one in the lbz and newer:confused:
Is there alot of people wrecking the crank? I thought we where good?
Shows you what I know:D
your always one step ahead of me arent you:D
