Forged Vs. Billet Rods
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I like the FPO. Some of the high HP engines have started to flatten the bushing in the small end. Perhaps this extra lube will fix this issue. Time will tell.
I cant see it hurting
If it doesn't I'll just get rid of the bushing and go with a DLC pin.
DLC? Direct lubricateing crank?:eek:
Thanks Tripp your like 10 steps ahead of me:D
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Do you not think the main studs from ARP are enough Adam?
Block could be a issue,Since GM decided to build a stonger one in the lbz and newer:confused:
Is there alot of people wrecking the crank? I thought we where good?
Shows you what I know:D
your always one step ahead of me arent you:D
Im always one step BEHIND you brother. Your close to completing a build and I haven't even done things I said I would do 6 months ago. I blame it on work....I hate it.
I dont know if I would worry about the crank, there hasn't been many failures that I have heard of either so I think its alright.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Simon I think he is talking about a Diamond like carbon coating. These coatings reduce friction and have increased wear properties.
So Is this something we could get done? Do you need to make room for the coating?Tolerences? Got more info on this?
Sounds like it would be Expensive haveing a girls best friend in you motor:D
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Ill worrie about the crank when mine breaks:rofl:I have enough issues as of now
Thing is you try to be prepared,Do the research and spend the money on the right parts and then WHAM someone comes out with a new issue and new fix!:rolleyes:
I know what your doing:D Waiting for the perfect moment to do your build;)
And ya X2 on the work SUCKS
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
I think the thickness is usually in the microns. I never have messed with it personally, Guy would be the one to ask that question.
719
i have heard several talking about the crank walking... outside of a spun bearings. there is two reasons for it.
1. main caps/bolts studs flex - fix studs
2.) main webs in the blocks start flexing- fix gridel
iirc NG never had a gridle... could be wrong
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Knew i should of bought the girdle
Trippin
SoCal Diesel
Aug 10, 2006
663
Diamond Like Coating. Measured in microns.
Super hard, super slippery. OK get your minds out of the gutter. :rofl:
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Whats up with these R&R Racing Products pistons? Anyone here running them? Anyone know of any experience, etc with them?
R&R Pro Chevy Duramax Diesel Billet 4340 I-Beam Rods with ARP 2000 rod bolts and Ampco 45 TM pin bushings. In-stock, limited to quantity on hand. If out of stock, please allow up to 12 weeks for delivery.
All R&R Pro Billet 4340 Chromoly Steel connecting rods are cryogenically treated, triple-tempered, vacuum heat treated, magnafluxed, rockwell tested, and balanced.
$2700 on their site.
ZR1160
TT Dmax Junkie
Jan 12, 2007
221
Eastern Canada
I think they make the TTS rods. IIRC
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
R&R has a good rep from what I've heard. But I'm sticking with Crowers from SoCalDiesel because even when I tore the pistons in half at Bonneville, the rods didn't fail.
It's just one more thing I don't have to worry about.
