I need to buy a new flexplate for my build and I am lost on what I need or not. bd is the cheapest option, but I didn't know if it was worth it to go with a socal or something lighter
Like i said, call me tomorrow and i will take csre of you
Andrew the flywheel on the right is for an internally balanced engine as it appears pretty uniform I think. But do all the holes affect the strength?
Or has it help some really big power already?
The SFI Spec does not just mention strength, it is to be sure pieces do not fly off like a grenade.
I also know when I built my house, I drilled large holes in chunks of wood for pipes and wires. I was told that did not significantly affect strength.
I like the lightweight of it. I have never seen Mr. Moody's flexplate, but they one in your picture looks great.
What is the most torque, or weight/ power(track time you have put through one so far?
Any truck pullers using them?
Build a zero balance motor, Buy one and find out
Internally balancedWhat do you mean by "zero balance" motor?
