Hmm that makes sense. I know that tire will 60 good if the track is prepped and the truck is setup.
same here, its all brian or steve ran at the track till bri bri went full retard and built a race truck .
:spit:same here, its all brian or steve ran at the track till bri bri went full retard and built a race truck .
Ya my buddy is running the exact wheel and tire combo but on a SC/LB 6 liter and his best 60 was with the Tires at 40 lowering pressure made it worse for him .. but I also thought lowering my keys all th way downI didn't get an alignment and I might have bBen riding on the inside of the tires and that could have def been hurting me I'm sure .
Did the white 03-05 dodge crew cab supercharged feeding what looks like a S472 run? I wasn't able to make i read on another forum he was making some test passes the weekend before but would say what it ran
congrats on the new time
lowering it down would cause the tires to toe out which isnt necessarily a bad thing. it will help in a couple ways.
1. there is always a little give in a steering even with the stoutest setup, that give will want to make the tires toe in.
2. when the front end lifts, the tires will toe in
having it aligned when lowered isnt the best idea IMHO. a little bit of toe out will help keep things straight. if its still toeing in bad, you have too much front end lift or your have some worn parts you need to look into. Cognito braces can hide worn parts when you go to check them so keep that in mind if you have them
8.17 1/8 mile = 12.75 1/4 mile
8.37 1/8 mile = 13.05 1/4 mile
That's a good bump.
I hope man that would be great !I have a rol pan on now and taking the hitch, and tailgate off this time and no longer have the gooseneck in which was on last time I ran I will weigh her before the track hopefully and post it..
I second everything Dustin posted about your wheels and tires.
how much does a set of those cost real 16x10 with 6''bs up front and 5'' in the back?
