Fastest stock turbo/trans Dmax?
KEVINL
1,431
Phoenix, AZ
You still talk about that... I am making WAY more power than you are and my head gaskets are still intact. My EGT's are lower than yours and I run 3300pw with big timing. Blowing head gaskets with stock bolts is a gamble... you took a chance and the cards didn't fall in your favor.
The HTT 66mm seems like a great option... only problem with going with a T3 pedestal is you can only go so big, with a T4 sky is the limit.
Damn 114 MPH
The 4094 didn't really fit my needs with the lift and the tight converter it was laggy I like quick spool I came from an Sti which has basically no lag at all
The egt's are a known problem with the 4094 its not just me my stock turbo only hits 1600 peak.
I am trying to save my pennies for some twins :D
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
The 6.0 is a fricken disgrace. Diesel Power had a 6.0 that had blew its motor at 70,000 miles it now has a built motor and it runs 14.0 flat.:rolleyes:
White 6.0 2wd in this months right?
Tim blew it up running 100% methanol.
his fastest time was 13.65 @ 104 about 2 months ago when I was racing with him
At the time Harry did the photoshoot, he was running 14's.
:thumb:
paint94979
Beer Nazi
Sep 18, 2006
11,715
Damn 114 MPH
I want to go this route eventually as well:D
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
You still talk about that... I am making WAY more power than you are and my head gaskets are still intact. My EGT's are lower than yours and I run 3300pw with big timing. .
Well arent you special. :rofl:
Kevin also had 150k on his truck when his HG's let go.
Philtopgun
Nice n Easy
May 5, 2007
710
45
Edmond,OK-still a Texan
You have got to be kidding me right? I have NEVER heard of a CC/SB LB7 or LLY run a 12 second ET with a stock transmission NEVER... I have seen the 6 speeds do this
NOPE:)
No I can't explain any further without teaching everyone how to build a better converter which I won't do.
The 6 speed converter is weaker to begin with and cannot be built as strong as the 5 speed... (Courtesy of Mike L.)
So for you to say its way better, aaaaa, that can be just a personal opinion. drivetrain is only as strong as the weakest link.
paint94979
Beer Nazi
Sep 18, 2006
11,715
NOPE:)
that was not the question at hand... you said the 6 speed converter is weaker therefor the 5 speed transmission is stronger... THE 5 SPEEDS IN STOCK FORM ARE WEAKER THAN THE 6 SPEEDS, the 6 speeds hold more power.
Philtopgun
Nice n Easy
May 5, 2007
710
45
sorry paint fumes. I was thinking more of the entire truck running down the road and not just the 6 speed tranny. Maybe the 6 speed tranny is better, Ill def agree to that. Then couple it with the 6 speed converter, the 5 speed tranny with the 5 speed converter, and maybe its NOT so much better, just better maybe:book:
:hug:
13,751
821
I will say it has been my experience that in stock form, a 6 speed transmission will hold more power than a 5 speed.
