Tryed bleeding it at the rail but the problem is the pumps are not pumping the fuel up to the motor? But they are running for sure. TTS pumps only run for 3 seconds and then shut off till the motor is running and i think that 3 seconds is just not enough. Im going to try and hard wire them so they run constant when the key is in the on position and see if they get the fuel up to the motor or not
