The DELPHI ECM's can't do balance rates while moving or on the throttle, so you only get one at 0MPH and throttle at 0 as well. Ramping up the rail pressure sure helps to show which ones are dribbling.
I knew it would do that If the accelerator was pressed but mine go to zero when ramping up rail pressure in the DVT tab while monitoring real time without recording. I thought you meant it will work if you "record" real time in the scan tool. If it does actualy work when recording thanks for the info because I chalked it up as a big o well. Just never had the desire to save logs from balance rates.
