Edge cts gripe
Nov 4, 2012
182
Harrisonville Mo
It's a ground prob I have had 2 probs and 2 new cts and they all still do the same thing if I just have my key on to run with the cts on and I roll my window down it spikes to 2000 same as if I am driving down the road and hit my brakes it does the same but if I am just driving it works fine kinda sucks but I have just felt with it edge has the best customer service I have ever felt with hope may e this will help some of you guys out
AKlowriderZ71
May 14, 2012
719
Wyoming
I'm betting it's a bad probe. Seen it a few times. Seems to be hit or miss, depending on the manufacturer of the probe. And Edge doesn't deny it at all, so they know what's up. When these things act up, they aren't linear at all. It's BAM, 2000 degrees, right out of nowhere. When it happens, you know right away that it isn't possibly correct.
But the hair on the back of your neck stands straight up anyways.....:rofl:
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
Brian, go smell you exaust, have james in the truck and put it in drive so you get the engine under a small load while you are doing it
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
still think you should do the smell test, get up close to the exhaust while James is in the truck.
James, make sure you record it to put on youtube as a how to video
6,020
worlds worst troll.......... :D
I could use a piece of paper to check to see if the valves are leaking by holding it against the exhaust tip with the engine running. UTI kid says it works!
Janimal444
354
Salem, NH
I'm on my 3rd EGT probe:mad::mad:. I will be yarding that P.O.S and going back to a 3 gauge pillar setup. I actually like the CTS a lot itself, and might leave it, but I am done with trying to use it to monitor EGTs
Dirtymaxx03
3,109
I am gonna guess someone has told you that before? My god, some peoples kids :confused:
6,020
yup. kid from UTI went on to explain to me how doing this method on a suzuki samurai will tell you if the valves are bad cause the motor will suck air back in as the piston goes down so the piece of paper will be sucked into the exhaust when it does this.
I had to take him back to engine basics 101, draw pictures, speak very slowly, and tell him "good job" many times when he finally started understanding things. i wish i was kidding but im not. ill see if i can find the old thread. ill have to copy it over as the board im on is private to only suzuki guys in AZ.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Contacted Edge, their sending me a new one under warranty, so we shall see how long it lasts.
Thanks for the help guys :hug:
