Dyno Explosion
durallymax
Apr 26, 2008
2,756
Under The Hood
thats not the first cummins i have seen that split the block! they split along the freeze plugs and the cam. there is another vid on youtube about a tractor with a cummins in it that did the exact same thing shows pics of the pistons still in the chassis lol
here is the video
http://www.youtube.com/watch?v=ICuSgp8er-E
that tractor is a DT466 Block not a cummins. The original poster did not post it correctly. Dont know why, dont remember why, hence why the comments were disabled. If you look at it a little closer it becomes very obvious it is a 400 series block versus a cummins. Add to that the fact that engine and sheetmetal need to match in a lot of classes of tractor pulling however not all of them as could be the case with the class this tractor was in.
As for the OP, that is a prime example of why they require straps/cables in pulling and such. If the safety gear wouldve been on there wouldnt be a hole in the ceiling.
05chevy
1,086
That's nuts. There's another video on youtube with a alcohol tractor that did the same thing. I bet the guy shit when it happened. I know I would have.
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
Matt Conrad, the one with the yellow ford bodied 3.0 trucks that build weight boxes? I heard that was a big cube motor...
SmokeShow
6,818
Lawrenceburg, KY
Yeah, that's the guy rob. I don't imagine that failure hurt him too bad financially. They roll into pulls in high class style. I'd guess their hauling setup is well over $150k.
Their engines have always sounded different to me. I commented about it one time & I believe 05smoker mentioned that matt teams up with DMS & they were doing some things different than most, hence, different sound. I know it sounded odd but holy moly when she came alive it was the real deal!
That's still insane catastrophic failure though. Wow! :eek:
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
That is the motor from Never Let it Rest. The block failed as you can see. Sleeves were still with the head when it hit the floor. No internal parts failed. They all were destroyed slapping the remaining half of the block. It was sickening to hear. This was a 20 year old kid that did the bulk of the build himself. It will run again. Just not sure how soon.
Motor was pulled to go dyno tune for the air to water setup. Truck gained a couple hundred hp just before this happened.
Pat the dyno is in Michigan. It is what GMS uses to dyno his super farm engines so it can handle the power.
FYI the hauler was dirt cheap. Truck they built not so much so. :D
jon5212
Oct 13, 2010
119
Wow that was intense. Not sure why they didn't shut it down as you could clearly hear it didn't sound right when it started to spool.
Iceman56
Jan 19, 2009
867
Madison, SD
So was that dyno set to tight you guys think? Seemed like it really pullled the shat out of the motor for a long time. Just curious I don't have any dyno experince
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
FWIW St Joe Diesel has an engine dyno that can handle it, ive watched 1800hp 4.1 tractors on it pull the motor down till it dies. We are working on getting it set up for a dmax now. Did that truck ever pull against the big boys? Haisleys, scheids? I was just wondering. Im not a fan if big cubes myself, and most big cummins guys tend to think the same way.
Fingers
Village Idiot
1,718
96
White Oak, PA
What is interesting to me is the engine dyno. Very few engine dynos will handle the torque a bombed diesel puts out. AFAIK there are none in the west.
When I was looking at dynos, they all recommended at least a speed doubler on the engine output for diesel.
durallymax
Apr 26, 2008
2,756
Under The Hood
I know nothing about dynos really but know that over here in the midwest there are plenty of dynos that can handle immense amounts of torque from pulling tractor engines, which make quite a bit more than trucks for now.
TIMTHECARMAN2004
Block Hole Maker
Sep 23, 2007
300
We have a ProFab 2 to 1 box that goes between the engine and the Dual water brake.
Seems to hold the big horsepower and torque pretty well.
SmokeShow
6,818
Lawrenceburg, KY
I was told they don't have $30k in their hauler.
Then they got a heck of a deal... What they were in at the last Stanford, ky pull of the year was NICE outfit. Perhaps I was over exxagerating but it's nice.
I'm foolish to have said that failure didn't matter too. IDK what I was thinking. Regardless, that sucked & is no easy pill to swallow regardless of financial situation.
I'm a dope. Sorry for talking a bunch of BS.
