Duramaxzak 2.6 pulling truck build
SmokeShow
6,818
Lawrenceburg, KY
Is the driveline rigid mounted or still have mounts w/ some flex? Are the fkexing too much? Not flexing enough & adding stress by making them a structural member of the chassis?
Just wondering out loud.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Motor has Merchant mounts, tranny has Energy poly mount. I never broke last year, but think the combination of new hitch and Mud grappler tires on the front this year is just too much for the T-case with the 3:42 gears. I'm going back to the Bfg a/t's for the rest of this year and will change gear ratio's over the winter.
MarkBroviak
DMax Junkie
2,141
499
Danville Indiana
It's a catch 22, 3.42's hold up way better than 4.56's do but the transfer case doesn't care for it to much. Truck is running great Zak, keep it up!
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
Tru Story, Unfortunately the Tcase is the best fail you can have with the 3.42's......when the pinion dose finally fail it usually exits threw a new window it makes in the side of the housing!!!
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Anyone ever see a steering box blow the end off of it like this? I was turning my pull truck around in the drive way yesterday and and heard a "POP", and the steering started getting weak.
