Duramaxzak 2.6 pulling truck build
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
It is alive!!!! Finally! Had a little trouble getting it to fire up for the first time. Thanks to Eric (WisconsinHick1) for helping me log it to make sure everything was working correct and Mark (Danville) for some new tunes and great customer support!:thumb:
I had to end up giving it a little shot of ether to get it going, but now starts fine on its own. Also part of the problem was that my Fuelab lift pump I have was for a Cummins so the pressure is set at 18psi, which I knew. But I didn't think it would effect the motor starting. I thought it would just idle like crap. I have an external Fuelab regulator I will regulate the pressure down.
Here's a crappy video of the start up. Only ran for a few seconds, because the cooling system is not hooked up yet.
http://youtu.be/NfUKN1oHmYE
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I have the dodge pump too. I was gonna put a boost reference regulator on it. But I didn't install it in time and I ended up cutting the spring so I could idle without coding at a pull lol
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
Anyone have pics of bent axles and stuff?
We bent this one,THis housing was towed in over 2"" at the edge of the tires, we bent DRW housing after this one not as bad but it junked a 3.42 pinion out the side of itso was junk either way, running a Braced dodge aam 11.5 now with the 4" tubes, so far so good!
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
Nice Build!:thumb:
