The reason for duals over one wide one is that when a tire is aired down for pulling the outer 2" does most of the digging. You go from 8" to 16" of digging area. That is what I was told by a good puller here in PA. Correct me if I am wrong.
1 single wide tires Helps you plant your rear end sooner. Witch helps you increase your ground speed.
