Does Wind Chill Affect the Morning Cold Start?
ChevyTruck
Boats an Hoes!
Oct 19, 2011
449
39
Newark, De
It was in the single digest yesterday and fired up just fine after sitting 10+ hours. I'm about to see how it does this morning with it being in the singles again. Only difference is that it's been down for 16 hours.
Yesterday afternoon it blew out a bunch of blue-ish smoke, should I be concerned? Only does it when cold like this.
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
Batteries are new. Cycled the plugs twice. Shit, I even sprayed a little shot of ether into the intake for that extra boost ( I did say little, remember ) and still no cigar:(
Nick
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,196
360
At Da Beach
Wow thats cool,yeah i know what your saying about the timer.My step father uses a timer on his trucks.I should get a nice time.......i do have a few nice intermatic timers maybe ill set 1 up with rubber covered cord and an outlet lol since i have all that stuff laying around.
I use an 8 dollar timer from home depot, works great, but cold to me is 20 lol...
Janimal444
354
Salem, NH
Nick
What was the temp buddy? If your fuel is gelled up you can be screwed too. You have any PS-911 and an extra filter?
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
-37C I checked for gelled fuel just in case by cracking the filter. It's good to go. A buddy is coming by to give me a boost.
This is the first time I've had trouble with my Dually. But I know that my Glow Plug control module took a shit. That in itself could be the problem. If I can't get one soon I'll look into just replacing the relay. I've heard it's been done before.
Nick
dracing70
SH--- GETTING EXPENSIVE!
Jun 12, 2007
1,210
45
mantua, oh
-15 windchill here today. Dually was not happy. It was hesitant. I could feel it was on the verge of gelling the fuel.
AubleAK
Aug 5, 2011
781
30
Glennallen, AK
Nick
You should start fine with out ether. I'd replace the glow plugs.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Nick
That's pretty friggin cold, -34F... Deff. want all 8 glow plugs working or she won't even try to start.
yellowchevy
1,926
82
Louisburg, KS for now
I always plug mine in any time it's below 20 deg F, as others have said it warms up faster and starts easier.
I've added a heating pad to my transmission so I can warm up my transmission fluid too, I'm glad I did that too.
I may not have to do all this but it starts SO much better. Even with my pickup plugged in this Sunday when it was -20 deg F I cycled the glow plugs 3 times just as a safety measure; it started better doing that than just cycling them once last weekend.
Yellowchevy
baggedLB7
Goer
May 1, 2011
688
Utah
Nick
I have done it and it worked for me and it was way less money.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
Nick
If the glow plugs / module is bad, just unplug them all and start it on ether. Pretty much all of our older MF tractors need ether to start around zero or below if not plugged in.
SteveLBZ06
Jan 6, 2013
200
Central MA
the windchill affects my willingness to walk outside to start the trucks but they dont seem to mind.my lbz started right up this morning at 4ish degrees. my work lmm started right up too. our lly dually was not so happy about it but did start none the less.
07keo02
Oct 5, 2011
399
Phoenix, AZ
Mine always started multiple times in the teens without the glowplugs hooked up(I was working on getting a broken tip out for a while). I have a lot of faith in the duramax's ability to atomize fuel and cold starting don't worry me too much after what I've seen, with good batteries of course. That being said, I plug mine in every night in winter, it starts up the next morning very easily, no smoke, smooth running, and cabin heat comes much quicker. Fuel mileage is also much better after being plugged in overnight.
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
i thought ether was a no no on our trucks
It is a bad idea if you have the grid heater or the glow plugs hooked up (light it up on contact and "backfire", if both of those are unhooked it isn't great but you might need it to start if it is stupid cold
AubleAK
Aug 5, 2011
781
30
Glennallen, AK
Good battery's and glow plugs, you won't have a problem starting. I had 100k mile glow plugs on my 01 with brand new battery's. i plugged my truck in the night before at 9, but my breaker popped at my apartment when my buddy pulled in 20 minutes after and plugged his in. I woke up at 8 the next morning (-45 below zero all night) and went to start my truck. Cycled the glow plugs 3 times, didnt want to start, but did. Do those things, with a synthetic oil and you should be problem free.
Stevenmc89
Dec 22, 2012
58
Enterprise, Al
Must be nice. My GP controller is shot and maybe a couple plugs to and it sounds worse than a civic with a fart pipe in 30F or below! Not trying to hijack, but can someone educate me on just replacing the relay and not the whole controller?
ecc_33
Junior Member
Aug 10, 2006
1,925
39
Amanda, Ohio
Moving them to Carey ohio at nationals rock corey. Tommorrow i have to be at columbus airport to start another 627 at 6:00am :( Its going to be cold and snowy. We move dirt in all weather conditions.
