Pat, is this the processor you were referring to as far as already unlocked? http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=9461&Sku=I69-980X Time to upgrade.
mike thank you i just dont understand how doing this with computers will help health benefits
Mike, that's the King of the Hill today. Insane.
It has 6 cores, but acts like it has 12, and can be overclocked heavy.
Bad news is the price. In a year, it will probably be $600. And it uses a LGA1366? socket, and the 1366 motherboards are pricey.
There are other i7 chips that are really fast, but still affordable, look for an i7-950. Then in a year, replace it with a 980X.
But I like AMD because they are cheap. The most wicked AMD chips is a 1090T and they are $260. Motherboards are cheap too. Even a $100 AMD chip is pretty fast. The X2 and X3's are the ones that can be unlocked if your mobo supports it, and the cores aren't really bad. None of our AMD machines are more than $700 new, one of them was about $450 new.
Pat I think there is software on the cd that came with the GTX460 that will let you monitor the temp of the card. I read that on a forum when I was looking at video cards. Can't tell you which program it is though.
Hardware notes:
Updated an older computer.
GTX460, was 149.99 after rebate when I bought it (watch for specials)
Has a GPU3 TPF (time it takes to do 1% of a job) of 0min 55sec. ~9,500 PPD (points per day)
AMD 1090T (for AM3 motherboards)
TPF on a 6701 SMP job (2000000 step) of 9min 55sec. 7,500 ppd.
This requires a 400w or bigger power supply, and a motherboard that supports AM3 chips (most newer AMD motherboards are AM3).
I overclocked the 1090T 10% with the factory cooler, and it stays at 48°C (good temp) at max effort. Fan is really loud, must have got a bad one, because it's the same fan as my lab machines, and they are quiet.
The GTX460 is factory overclocked, so I didn't turn it up. It's real quiet. Don't know how to check it's temperature.
With 4 GB of ram, to build a machine like this from scratch:
Antec 300 Case + 430w powersupply = $90
4GB DDR-1333 Ram = $70
Motherboard = $90
DVD = $20
CPU = $260
HDD = $50
GTX460 = $150
Windows OEM = $100
Keyboard+mouse = $20
Monitor = $150 (tigerdirect has best monitor prices)
= $1000. Obviously if you already have some of these parts, the cost is much less. To do one of similar power using Intel is about $1400.
Pat where did you see the 460 for $150?
