Diesel runaway carnage
eric28miller
Newbie
Aug 12, 2016
24
Iowa
I have an s474 im gonna compound with the stocker for now and someday bigger. Short term goal, 600+ daily driver. I dont want to pull the motor again so i figure build the internals now and i can always do bolt on's later.. Idk maybe im going about this all wrong, thought about throwing in a good used motor and leaving it stock too
5,911
What's your power goal?
I'd skip the billet mains and put that toward parts you NEED, like valves and such :D
agreed
you wont need billet mains for that power goal or really till you start pushing past 1000rwhp imho (others may differ). what pistons are you going to run?
3,729
297
I'm at 660 RWHP on stock mains with just studs and a line hone. If you keep the torque reasonable, you can go higher HP without billet mains IMO.
A true 600+ WHP is a stinking lot of power in real life. 660 pushes my truck at 8,300 lb to a 13.08 @ 104MPH in the quarter mile. With a lighter setup, it'll rip like mad.
Sent from my FlashScan V2
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
Jesus what is on your pickup to make it weigh that much? my 05 CCSB weighs 6800-7K depending on how much fuel and if I took a crap or not that morning :roflmao:
countrycorey
Trust Me I'm an Engineer
Jan 30, 2010
1,512
35
LA
My ccsb weighed 8200 lbs last time I put it on the scale
Sent from my SAMSUNG-SM-G930A using Tapatalk
3,729
297
I wish I knew :spit:. I can't account for about 500 lbs of the weight. The rest comes from a bed tank full of diesel, tool box, air compressor, and lift gate.
eric28miller
Newbie
Aug 12, 2016
24
Iowa
I jumped on the salvage auctions and found quite a few duramax's burned up which would make a perfect donor for mine. i'm starting to lean towards throwing in a used longblock and running it stock while I build the original motor as I can afford it, which may take months to years to do it right. What year's will swap into an lbz platform? Correct me if i'm wrong but the LMM's are almost identical other than the emissions but what about LML's?
3,729
297
If I recall, any 2003-2006 engine (LB7-LBZ) interchange electrically, and any 2008-2014 (LMM-LML) interchange, but you can't put a LML into a LBZ body and have the electrical systems "talk".
5,911
to drop in and go, you need to look for any 06 LBZ to 10 LMM. if you get an LMM, there might be little htings here and there you need to change from LMM to your LBZ though i cnat think of any off the top of my head. the injectors are different at the tips between the two but the same otherwise.
03 lb7 to 05 LLY use a different crank reluctor wheel. to use your ECM, you will need to either mod the reluctor wheel or swap yours onto the crank. you will also need to use the 03-05 balancer and fly wheel, do not use yours, they are different. to save headache, i would just use the short block of the 03-05 stuff.
LML you can pretty much just use the short block but again, IIRC the crank reluctor wheel needs swapping and you MUST use the balancer and fly wheel that are on LML engines. then you can bolt on your top end and go.
easiest route is 06-10 engine. gets you good heads too
eric28miller
Newbie
Aug 12, 2016
24
Iowa
Great info!! Thanks man! Appreciate all the help from you guys. Haven't been on duramaxdiesel's forums very long and I can already tell it's a very close-knit community here :hug:
eric28miller
Newbie
Aug 12, 2016
24
Iowa
Anybody recognize this truck?
Lparrill
And here we go again
Jul 30, 2010
445
9
Lander, WY
Yes, regency was was a third party company that customized new trucks from GM before going to dealerships, they have since gone out of business. Most regency packages had fancy paint, maybe interior work, and lift/tires. These were sold for a premium markup at dealerships. Fairly common in the Midwest.
eric28miller
Newbie
Aug 12, 2016
24
Iowa
Huh can't believe I've never heard of them. From what I can tell they reupholstered and added heat to the leather seats, leather on the door panels, painted the mirrors, billet grille, rims, chrome tip and Regency badges. Wish I could of seen the truck before it was wrecked I bet it was pretty nice!
Well if anybody is interested the seats and door panels are for sale.
Dozerboy
4,916
496
TX of course
Ya Regency made pretty nice trucks. I didn't know they went under. They would do anything GM I think. I know I have seen Vans and SUVs.
eric28miller
Newbie
Aug 12, 2016
24
Iowa
Update: So found a complete lbz from a local guy who was pretty sure it only had a blown turbo but wasn't sure. So I brought it back to my shop and did a compression test. Found cylinder #1 had no compression, rest were around 280psi. Pulled the head tonight and found the culprit. I have a set of standard bore LB7 pistons but im worried a hone won't be enough. Ill take the motor into Empire next week and see what they have to say.
