Diesel runaway carnage
eric28miller
Newbie
Aug 12, 2016
24
Iowa
Thanks MadMax17
Here's the receiving donor truck. Gotta shorten the bed 1ft to fit the duramax chassis.
Ill shud pry start a build thread in the swap section
3,729
297
Its just another cummins swap that i got way too carried away with.
I know that truck! I've been following it on YouTube since you started building it. Good stuff.
Looking forward to see what you do with the DMAX. If you put half the effort in you put into your white truck, it is going to be epic.
Sent from my FlashScan V2
eric28miller
Newbie
Aug 12, 2016
24
Iowa
Lol thanks Dave, thought i could quit after i finished that one, but all i can think about is how awesome would a duramax swap be! We run 2 on the farm and im very impressed with the beatdown they've taken over the years!
eric28miller
Newbie
Aug 12, 2016
24
Iowa
After some bloody knuckles I got the motor pulled out tonight. Tear down begins tomorrow night ill keep ya'll updated with pics.
eric28miller
Newbie
Aug 12, 2016
24
Iowa
Well now I see why everyone uses aftermarket motor mounts..
Oil everywhere.. apparently a mouse made himself home at one time
valve spring bout fell out when I pulled the passenger side valve cover off
Need a few of these if anybody's got em
There it is, sure glad it didn't break off and take out a cylinder
eric28miller
Newbie
Aug 12, 2016
24
Iowa
The worst piston, but none of them cracked surprisingly. You can see where the outer edge started to melt away..
Driver's side.. Would you guys worry about that discoloring?
5,911
Only cylinder wall damage I found was on this cylinder, i'm hoping it can be honed out what do you guys think
can you feel it with your finger nail? also need to know the current bore size as well to tell ya if you have much room to hone.
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Bent push rod are not a bad thing if they were the only problem. If something has to give I'd like it to be something cheap and the weakest link. The guys who put in billet push rods are doing it backwards in my opinion. They are cheap and easy to replace.
3,729
297
You'll need to get an accurate bore gauge to see how much you can hone out before you hit the service limit of the block.
I ended up with a couple light scratches on my cylinders (couldn't catch a fingernail though), and it doesn't have any ill-effects. Compression is good, no oil consumption, etc.
Since a hone is cheap, you might try honing it out a bit, and see if you can catch a nail on the scratches anymore. If not, you're probably good to go.
5,911
Yea my nail catches it...Just stock bore, I don't have a bore gauge to get exact
yeah id have to know how worn the bore is and what piston/size of those to know what you could get away with. its more than likely going to need a bore. .001-.002 hone isnt much and thats about all you can squeak out
5,911
service limit isnt so much the concern as piston to wall clearance.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
If you run good heads valves won't stick. And therefore good pushrods won't have any I'll effects.
Stock pushrods will not take the pressure required to keep up with stiffer valve springs, high RPMs, and elevated boost and drive pressures.
Subman
Old Geezer
Jun 27, 2008
3,233
80
Totally agree with running good heads for sure.:thumb:
eric28miller
Newbie
Aug 12, 2016
24
Iowa
I just got off the phone with Chad at Empire diesel. He recommended going .20 over because the cylinders usually warp when pistons melt. They can do all the machine work including billet main caps and throw in the used carillo rods I have for around 2500. For another 1200 they will assemble the short block. I'm leaning towards just having them finish it out to a long block and be done. Their shop is only 30min from me which will save a few bucks on shipping, now I just need to find a money tree :thinking2:
5,911
2500 including rebuilding the heads?
