As for my warranty comment, it was more interesting to see how members of the board felt about built motors and warranty than anything. Believe me, I've already had to deal with it during the past 8 months building my truck, and I am 99.9999% sure I'll have to deal with more in the near future. My thought is, if I was in your shoes, that I would consider warranties on "builds" on a case by case basis ans I'm pretty sure that's what you already do. So hat's off to you.
As far as Owens truck and the pistons, were you using Mahle Forged pistons that were the "same" as Socal's (in metalurgy) or were they more like TTS (in metalurgy)?
Thanks,
Tim
Piston Thoughts -
Four kinds of pistons failures I've seen:
Cracked across pin - LBZ/LMM is when they push the bushing in wrong and start the crack at the factory. Others from high pressure and temp.
Ring land collapse - Normally when using forged, happens when there is blow-by.
Erosion - Lots of high pressure oxygen, high piston temps, and high fuel pressure will ignite the aluminum pistons. This is the star you see on the crown.
Seizure - High oil temp, tight clearance, high piston temp.
Here's the weird thing. I've hosed a "few" sets of pistons at this point. With both low PW and high PW (rumor has it that high PW wrecks pistons, but so does low PW in my experience), but have never cracked either an LBZ/LLY or Forged. I have seized, eroded, and collapsed rings. High RPM is your #1 enemy it seems. All my piston failures involved 4000+ rpm WOT operation. I wasn't seeing piston issues until I moved the shift points up.
But high RPM is what makes our trucks shift sweet, and saves the driveline and IMO the crank (never had a crank issue).
