eh, that pump may or may not hold then. it may hold down low but when you start hittin the higher R's it may start droppin out
Nick how high did you rev your motor? I had one do the same thing, stock pump, and I was told to the person who built my new pump that I over spun it. Shifting at 4200rpm.
Is that what is killing these things? Not the fact that they are strokers?
So all the plugs are still intact?I ran mine to 4500rpm for awhile... Shane said that my pump had a ceramic check ball in it... Bosch had a recall and now uses SS check balls? so im not exactly sure what the issue is.
When those balls flake off they just ruin everything past the cp3. They don't leak like that.
I ran mine to 5,200 lastnight :rofl:
to get the lower left CP3 bolt that coolant line is in the way... I guess I have to pull the alternator right?
