Danville Performance 72MM VVT
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
Just left the dyno after installing the first Danville Performance 72MM billet VVT!!! Mark Broviak definetly knows how to build a turbo! My dyno numbers don't give the turbo justice considering I'm stock bottomend and only 45 over injectors single pumped. I made 634hp with no tuning adjustments. I make more power quicker and stubstain it longer on the big end!! Should make the 11.90 class for sure. I can't want to run at the track!!
paint94979
Beer Nazi
Sep 18, 2006
11,715
You will bend your rods with that much torque... Tell your tuner to detorque your tune
1,833
Bet they already are, he just doesnt know it yet. ;)
Curious if the starting 615/1080 was done on the same setup just minus the new turbo? Same dyno?
Would be interesting to see this charger tested on an engine built to fulfill its potential. Test before and after turbo install.
1,833
My rods are fine by the way!!
Sure they are....keep telling yourself that....1200tq, no matter how you made it, is a recipe for trouble on a stock bottom. Thats fine if you want to throw caution to the wind, but Ive been there, done that. Just trying to warn you.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
What the F is with all the negativity lately? I think he is well aware of the dangers, he has been on here awhile... Can't someone be excited about there truck without someone calling them a liar? Lighten up!
