Cranks
5,911
Here is a clue.
attachment.php
Is this just a fancy question so you can show you get the cyl pressure setup working? Lol :D
Fingers
Village Idiot
1,717
96
White Oak, PA
Here is a better graph of position, velocity and acceleration. Keep in mind these are for a piston without load and constant crank RPM.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,517
501
Central OH
I don't think it does. You're telling us that an inherent design of a piston engine is to blame for diesel rattle? Then why doesn't a diesel engine converted to CNG or propane rattle? They run the same stroke/bore, and even more compression than a gasoline engine due to available higher octane.
Dave c
Jul 7, 2013
294
If that were true every engine with similar Stroke, Rod length, and CH would rattle. Diesels rattle from delayed ignition timing of the fuel mostly, causeing variances in pressure in the chamber.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I have no clue what causes the rattle but an old gas engine sounds somewhat like a diesel when it detonates after the ignition being cut off.
