Cranks
Fingers
Village Idiot
1,717
96
White Oak, PA
Quoted from Gale,
"As to Vibration dampers with neutral balance, we designed a 2 piece assembly that allows us to drive accessories, like a dry sump or blower drive off the front. We make 2 different size inertial rings and tune each differently as to viscosity and clearance to tune to stroke length, bob weight mass and maximum rpm. The inertial ring assemblies bolt to our drive hubs which are zero counterweight or are matched to the various standard Dmax counterweight masses. We own Automotive Balancing Service, started in 1953, it is the first and the oldest automotive balancing shop in the United States. Today, we use the shop only for development and our own internal engine production needs, but we know balancing! We therefor know that the position of the counterweight is incorrect in most of the hot rod Dmax balancers being sold today, that leads to crank failure. We measure crank twist front to rear with the engine running at a wide spectrum of speeds and loads…we don’t guess at this. I seek a maximum of +/- 1/8 degree crank twist
We have made very high output with properly inspected stock cranks and proper attention to the damper design."
This quote has bothered me for a while.
First, the dampener does not prevent twist. Runaway twist from harmonics maybe, but not the actual twisting moment on the crank. Degrees of twist is actually the wrong metric for the effectiveness of a dampener.
The rotational movement of the crank on any reciprocating engine is not smooth. Far from it. It will speed up, slow down, even reverse direction for short moments as it rotates through a revolution. The purpose of the flywheel and dampener is to try and smooth out these variations. With the Dampener also acting as a harmonic absorber.
Diesels are notoriously variable and bad enough to have dual mass flywheels used in their manual transmission applications.
So the real metric would be more like % speed variation or something like that.
Now, the crank itself must be able to handle the twisting moments applied to it. THAT would make sense in Degrees from end to end.
Fingers
Village Idiot
1,717
96
White Oak, PA
I'm just getting my feet wet with the new software, but so far, it looks like those uncommon failures on the Flywheel side of the cranks are probably from hard shifts.
Interesting.
duramaxnokaoi
60
Quick question. Is anyone cryo treating any parts of their rotating assembly? If so, has anyone broke a cryo-treated crank?
Mikey
Drag Racer
Jun 13, 2009
560
3
Interesting.
I bet a lock box doesn't help either. In terms of harmonics and not power to the wheels. The converter has some dampening I imagine, but that all goes away when all locked up
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Nice Fingers
I have always wondered on the same lines as you are seeing. That's why I have been saying mine "should" have broken 10 times over. A sudden lockup at full power I think is hard on the crank. With the power some are making when it goes to lockup something has to give. Good info! Thanks John
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
When were you pulling lockup? We had 100+ passes on the Chevelle, and didn't start having engine issues until we started pulling lockup right out of the gate, now that I think about it. #4 bearing was flattened and squished around the main both times.
Fingers
Village Idiot
1,717
96
White Oak, PA
The model I am using for the crank is far from perfectly faithful to the actual crank. The throw thickness is accurate as are the bearing journals. Its the finer details I am lacking right now.
I am learning how to add a dampening force now. Cool stuff. It better be for the price.
:D
Fingers
Village Idiot
1,717
96
White Oak, PA
A small update.
One of the features of the new software is the ability to create bearings. That is, constrain a surface in one direction. So I can model the mains on the crank and support it like it is supported in real life.
With this feature, I found some interesting things, and some a little confusing.
Let me put out a teaser. When you load up one end of the crank, the OTHER end is where the forces concentrate if the other end is fixed. (or has a lot of inertia)
SmokeShow
6,818
Lawrenceburg, KY
What do you mean by "load up"? Load applied perpendicular to the axis of rotation, load applied parallel to the rotation axis (push/pull front to back) or rotational force (torque) ??
SmokeShow
6,818
Lawrenceburg, KY
I would guess it assumes the "bearing" doesn't crush or move?
You say the force concentration shows up at opposite end of crank from which the force is applied? Is this a steady state (analyzes one frame in time) or dynamic analysis (takes into account the actual movement & "records" some parameter(s) like stress, strain, deflection, movement, twist, etc? Is force concentration on oppopposite side of crank as applied load or same? i.e. crank is bowing (forces on same sides) or teetering (forces on opposing sides) about some axis?
Mikey
Drag Racer
Jun 13, 2009
560
3
Nothing here makes one stand out more than another except the rhetoric. IMO
Ideally, you would match the balancer to the built motor. Most of us can not afford that.
Or do a zero balance and put the zero balance flywheel and damper on?
But then again more expensive, but going that far into a build would make it a drop in the bucket. You don't see any high performance gas engines externally balanced do you?
