The out of the box version is only a small 83mm tw so that is very tight
from mobile
That particular LML kit Is using a t4 with 87 turbine. Cast 75 comp.
Plow boy,
That's only on the LML emissions compliant kits. It works excellent and is a blast to drive, currently supporting 640 rwhp and all pressures are still in check. Although it is a more costly turbo so you won't see it in our basic kits. The t6/87turbine 1.10 ar is more cost effective and works very well. They are not as popular and you usually don't see them used much, mainly because the box 475's are cheap with the 1.32. but I bet if you tried it out (the 1.10) you wouldn't go back :thumb: again, being on a stock injector/pump truck. If your planning on pushing an s475/stock twin kit hard and adding fuel then you'll opt for the larger AR obviously..
