That's a very odd turbine housing. Whats with the vband?
That's what I thought. Never seen a setup like that, but Dan says they're out there and link here as example: http://www.tialsport.com/index.php/tial-products/turbine-housings
what does your MAF limited fuel injection quantity table look like in the tune?
There is no MAF limiting whatsoever.
Truck gets full fuel when trying to boost launch.
now that makes sense!:thumb:
what he said
What are the MAF readings at idle? Does it hold rail?
Sent from my DROID RAZR using Tapatalk 2
Do you have a waste gate on it? And is it stuck open or cracked open?
No waste gate. Like Mike says that is what Elevation is here.
Elevation here in SLC/Ogden area is 4500ft. Deffinately not ideal.
DA is also over 7000 i believe.
I remember I once installed my maf backwards and it wouldnt run very well
