Can't get truck to run after bigger turbo.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
It smokes at wot. I know my truck with the smaller charger is very much fuel starved, it is essentially smokeless, and under full boost it is smoke free all the way down the track.
MarkBroviak
DMax Junkie
2,143
501
Danville Indiana
Ok guys, let me fill you in on that turbo. What you have there is an open non-divided stainless steel 1.0a/r custom 3" vband inlet with an 87mm turbine. That is designed for big flow and you don't have it so it has no drive pressure. You need to drop back to the 83mm turbine in one of those housings or go back to a conventional t4 divided 1.0 housing. I'm not a fan of the ,90 housing on a dmax and I use the 87mm turbines religiously. I have't been brave enough to try that combo you have because how much it flows. I build 96mm versions of it for Bullseye for the big gassers and they run them parallel twins!
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Ding fking ding!!!!
YOU DA MAN!
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Well Ryan at least now we know. Without you sending those pics of the setup we may have never found this out. Huge thanks to mark for chiming in here. Ryan if I were you id buy a 472 or 475 with a standard T4 housing and let that truck eat. You might be able to sell that big charger to some of the guys here who run huge fuel.
red1977
Nov 15, 2010
786
47
Ogden Utah
So I can run the 87 mm if I go to the different housing? Can I just do a housing swap or is there more to it?
MarkBroviak
DMax Junkie
2,143
501
Danville Indiana
The charger you have there is something that will flow well over 1,000+hp and keep drive pressure at or less than 1.1 all the way up to 5,000rpms in a 6.6L fwiw.
red1977
Nov 15, 2010
786
47
Ogden Utah
I'll get if figured out, I'm just glad we know what was going on with it. I almost sold the truck for what I owe on, someone would got a hell of a deal lol. Thanks Bryan, Steve, Jake, Mark, and everyone else that was helping me.
Balindir
Rod shortning in progress
Jul 30, 2012
364
South Central, Pa
Learning something new every day... Gotta love it! :thumb:
