Are you going to anodize them, or powdercoat them?
I'm fixen' to ban sum folk who opined they're bigg ole pie catchers in dis tread...
I'll b back on Monday
You guys are confused. First of all the linkage goes on the ends and they do move plenty. Second, the rods are made of 304SS, so their is no need for PC or EA.
If you use the 26" rod like I did, you must de-burr it after the cuts are made or they will hang up. blow them out with a blow gun too...
The handling problem is caused by softer tires in the rear than the front. Soft bias-ply tires out back with stiff tires up front makes the rear try to steer for you. To get a feel for it, drop your stock rears to 20psi and put the front at 80PSI and drive around. Then put the fronts at 20, and rears at 80.
This has been a big problem with late model car drag racers, and is probably the number one reason folk go into the wall, closely followed by stabbing the brakes when the rear gets sideways.
Even if you CAN keep it straight enough, if you must steer quickly or brake going down the track, you're going to loop it. A piece of debris, some oil, or the other car coming across is going to leave you no options. You must just "drive through" and not react.
Slicks (cheater) on all four will work, we really can't put "skinnies" on our trucks due to weight, or at least dropping the front tires down low will help. Ballast won't help, since when it does come around, the ballast adds inertia to the spin.
BTW Powder coat would make the rod too thick and the surface inconsistent causing them to hang up. If the rods hang up the linkages WILL bend if not break.
Hmmmmm. I didnt deburr, maybe that why the ends dont move much. I'll try that. What did you do for the connection on the left side end piece where it goes into the bottom of the right side?
Going out "partying around"?
I disagree, I machined the rod down to allow for the thickness of the powdercoat.
I'm thinking Negro Modelos and Mexican food after I pick up dem tires on Monday:joker:
That or Taps? I will drvie back to the shop I'm craving ceviche :yumyum:
I used a dual linkage with an offset pivot and slide connector...
That's allot of unnecessary work to me, plus it leaves you with an inconsistent surface that is weaker than OEM...
What is ceviche
Kat is the only one to answer this question :cop:
Cool, I thought the slide connector was real hard to get? Can you still order them or are they discontinued?
I figured just a little machining wont hurt, plus I sleeved the rod on the inside.
