Broken Crankshaft Count?
Please pick the one that you had break
  • Total voters
    185
2006 LBZ
Feb 8, 2011
195
Calgary, Ab.
Look how heavy the harmonic dampener is hanging of the front of one of these cranks ;)
Plus i think i read that part of the crank spans the furthest distance un supported. I think some shop came up with some sort of stabilizer to help the issue but not sure on that. I thought i read it on here but who knows lol
Curtis Halvorson has made one and it works damn good for support...... but harmonics still break the cranks even with a internally balanced motor (with a procharger though) :eek:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Just a thought. Is the LML crank better in any way? I have heard that it is lighter, but not sure if you can fit a LML crank in a LB7-LMM block with same main caps? With LML pricing the way it is...
juddski88
Freedom Diesel
Jul 1, 2008
4,658
128
Chesterfield, Mass.
I'm planning to do it Brian. LBZ block, LML crank....same .0030"-.0035" clearance that it had with Clevite HX bearings. no block fill, no girdle. ATI damper and ATS flywheel as of now.
S Phinney
4,008
Quncy, Fl
Have you tried block fill before?
