670
I didn't find that specific diagram, but deducted crank signal from key runs through the BCM, along with DIC, PRDML information, warning light signals. Through several others
Found the BCM pin out. So I'm going to verify it's getting full battery voltage where it should be.
Doesn't explain the "relay clicking" noise under the dash.
Haven't found which wire/circuit actually turns everything "on" through/via the key yet either
2,307
This is the LMM starting circuit from GMs electrical manual. The ECM is what sends the signal to the start relay
If you have the key in the run position and jump out the start relay or even the starter will the engine start?
Reactions: malibu795
670
Yes engine starts if I jump the relay or starter itself.. though initially GP don't cycle, alternator doesn't come on, water, oil, fuel, coolant, tach, speedo, trans temp gauges are all dead., traction, brake, abs lights are on, T/H light doesn't activate, neither does the line under the PRDML light up, more often than not I can't connect to anything via a scan tool through the OBDII port
From what I've gathered it's switch/BCM/ECM/starter relay with all safety switches in their correct position
What rim posted
gmduramax
Shits broke
Jun 12, 2008
4,087
254
Nor cal
What rim posted
Sounds like an issue with the databus. One time while driving an LMM I had to clear codes and my V2 came unplugged during the process and everything went blank but the truck still ran. Pulled over and shut the truck off to get everything to come back on and truck wouldn’t start. Nothing had power, waited 15/20 min then heard a thud under the hood like the ecm reset and everything went back to normal.
2,307
I had something similar when loading a tune. Truck wouldn't start. Dash and other stuff acting weird. Disconnected the batteries for a minute and everything was fine afterwards
I agree, looks like a data line issue. The ignition switch is what notifies everything else when to turn on or off. And when the ECM should send power to crank. If this serial data line is interrupted or blocked from making it to the other modules then nothing will work as you experience
670
I've had the batteries disconnected for over 24hrs at a time during the week.. nothing changed. Even touching the cables together
If the BCM doesn't tell the ECM to wake up and crank it won't crank, seams it's waking up, but not getting a request to crank signal, hence why it runs when BCM is bypassed to crank
I haven't hooked EFI live up to it since i had to jump it at work. Didn't want to creater other issues due to failed scan/flash
670
Well.. dealer/official outside shop is ~850-900 with the BCM running ~500.00, GM wants 1.25 HRs just to r&r the actual hardpart🧐 a 15 minutes job.. and 1.0hr for programming which is roughly reasonable on the programing side
Found this guy.. ~200.00 with a reman unit, no core... running 4.6 starts of 158 reviews.
2,307
What about finding someone parting out a vehicle? Or a dismantler? I think as long as it comes from a vehicle with the same options, number of doors, etc then you only need to do a VATs relearn
