Blocking your intake resonator?
13,715
779
I've personally never really seen a reason to block it, but I know a lot of guys do it. If you do and you use one of those expansion/test plugs that has a cairrage bolt with a wing nut or something similar, make sure the nut stays tight. Also, it would probably be a good idea to use one that has metal ends instead of plastic. I just saw this a couple of days ago.
attachment.php
attachment.php
attachment.php
jlawles2
1,059
40
Danbury, TX
The plug I found had a metal washer that was too big for the resonator to fit back on the truck. I ground the washer down but it still will not fit down the hole. And it is a tight fit.
As for the bolt, It is drilled and has a safety pin in it so it cannot drop into the intake.
Also when I blocked the PCV, did the same thing, drilled and installed safety pin.
13,715
779
That's a good idea on the safety pin. I'm not sure if anyone else sells them, but Alligator sells a billet plug with an O-ring seal for both the resonator and PCV.
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Sadly my compressor wheel looks just like that but it happened before i had the truck :( oh well ill put a batmo in one of these days.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
Why not use a 2" rubber cap? No way for anything to fall in and it fits perfect.
I removed mine for access, I don't think there is any performance gain at all.
Sent from my ADR6400L using Tapatalk
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
X2 on the rubber cap. Worked great for me also. Did a few friends that way to. No issues. Took mine off now cause of the mpi twins I'm installing this week.:D but would use the cap again for sure.
JMK777
16's, but i keep em clean
Mar 20, 2008
1,433
5
Moss Beach
What is wrong with a $3 rubber cap and hose clamp? sticking something in the hole is asking for it.
13,715
779
Untill they crack and let your sweet engine eat dirt. Ive heard of too many cracking along the seam and alowing unfiltered air into the intake.
I have never seen one crack. Not saying it can't happen, but I can't believe it's all that common.
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
Think its more of a first generation engine issue, plus there might be something in the air here...LOL! There are 2 i know of here locally in my dinky town, and a few ive read about online. I think its prety cheap insurance, provided you do it right.
