Blocking your intake resonator?
2,064
Geezus...why the hell do you guys use that plug and risk the turbo? Buy a cheap 2" Fernco cap and be done with it.
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
Mine cracked so I did this
Stealer told me to put it back on I did the other plug and put it over it so it looked stock.
dmaxman06
May 25, 2011
493
morenci az
i used the orignal rubber piece that joined the intake and rez together and then used a grease cap off of a nissan sentra clamped it down with some silcone for added protection
... i did all that cuz i could never find the rubber plug everybody else has at my home depo
Dragonsfireloki
Nov 6, 2011
175
North Dakota
The reason to block it is two fold, first is to avoid the cracked resonator like everyone else has stated and the other reason is that it supposedly makes the spool of the turbo sound louder. I plugged mine for both reasons but didn't hear much of a change in sound, but i don't have a resonator to crack now.
mainer
Nov 11, 2008
326
the fernco caps dont work well with twins, the blow off easily.... thats the only reason i can think of that guys are using the plugs instead (this would apply on lly's + )
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I don't get it? Mine has a simple cap on it with a hose clamp
It's been like that for 6 years..... Why would it crack or blow off?
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
just curious as to where you would put a fernco cap or plug on a trwin set up?
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
How come?? Donit most twins kits replace the intake with a custom piece....shouldn't need a cap or plug then???
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
Danville Performance makes them as well. Even custom ones that can be cnc'd to say whatever you want. Check out their Facebook page for pics and prices!
dmaxlover
Mar 17, 2007
453
WI
The nice thing about using the plug, is the resonator can still be used for that stock appearance. Just make sure you cross drill the bolt, and use a cotter pin.
