Question: best fuel temp
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
I got it all read. Too bad a few derailed it.
What I've seen and what I read in that thread are pretty close match.
I did install a cooler w/fan after the factory filter with temp sensors before and after. I don't think I'm done yet. I think even with that cooler, the factory cooler will be coming out.
I did get a pollack fuel valve to direct which tank the return fuel goes to, but haven't put it in yet.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Whats that about cooler fuel.....? :)
JakeGMCHD
May 17, 2008
29
Today it was -2*F outside cruising down the Interstate I had the fans running on the cooler with 66*F return fuel temperature.
Colt
Jul 23, 2010
523
Lots of guys like fuel cool regardless until it hits like 40 deg. and it's time to shut off the fans like. Thermostats are still kicking in from a warm setpoint.
catpower400
Feb 17, 2010
Can I check the fuel temp with my V2? My problem is cold fuel in the winter way up here in ND. Would be nice to know what my fuel temp is. Or im open to suggestions on fuel temp gauges also.
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Saw air temps drop to a low of -27 F this morning.
No gelling issues yet. I did stop and put in some Howes antigel when temps got close to 0 last night
My fuel temp gauge only goes down to 0 so I don't know what temp it is.
Been keeping the factory tank under 1/2 to try to get the fuel a little warmer.
nmband13
53
Sioux Falls SD
How do you keep from gelling? Special fuel filter heater?
Subscribed as well...
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
No extra heater.
With the exception of the aux fuel tank in the bed, and the extra fuel cooler behind the grille the fuel system is stock.
Fwiw, I pulled out of WI about 5AM outside air temp was -9. Bottomed out at -27 on the way thru Minn, and didn't see above 0 until 1 or 2PM. Wasn't running the grille cover either, because I was towing and ECT was staying right around 185-192
