bent rod!
kydmaxpuller
Mar 2, 2009
14
taylorsville, ky
i used to work at a gm dealer and had an lb7 come in with one of the worst knocks ive heard, not just a tick, like something was beating the hell outta something else. like everybody else said started turning injectors off one by one cut #6 and it stopped, changed injectors and ran good as new
13,765
834
Maybe try moving injectors and see if when you shut off the injectors one at a time if it follows the injectors or stays in the same hole.
02bigstrokin
Sep 9, 2008
882
I had one that sounded like a fuel knock and ended up missing a piece of the piston skirt. It had cracked and fell completely off. Truck had 150K on it and was an LB7
yeah but im leaning more towards what everyone is saying as far as it would make the sound all the time, my noise quits when you turn the #7 injector off. im going first thing this morning to get a compression tester.
02bigstrokin
Sep 9, 2008
882
If you are looking for one to use, I can send you my kit. If you are looking for one to buy, I got mine off the snap on truck.
thanks man but i think im just going to go buy one. it will just be another tool that i already have next time i need it or one of my friends needs it.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
I didn't even think of it with how you described it but I had a leak past an injector that was bad enough I could hear it all the time. Sounded horrible and I thought something was mechanically wrong at first. Pulled the injector out replaced the copper and the o-ring, stuck it back in and all was good.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
I am thinking it is something around these lines as he is also getting some fuel in his oil
