Bed mount trans cooler
moparkxracer
2,309
33
Out and about
One thing we did on a race car was drilled the Trans pan to run lines to and from the pan. We ran an electric pump to a cooler electric fan on it. It helped when hot lapping the car. Just something the we tried and it worked.
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
That's my setup, and mike is correct. BUT I cut a hole about 1/2 smaller then the cooler on the front that the cooler goes over and fans blow through. I've never seen trans get above 180 and last week it was almost 100 here.
Ok so you're drawing air from in the bed & blowing through the cooler toward a hole in the front of the bed. Did I understand that right?
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
We have them in one of our trucks. (Mikes truck) and his Trans runs cooler than mine does on a hot day and making passes at the track. They work great!
Thanks Nick!!!!! Eventually putting them in mine when it's not a daily anymore.
Mishimoto
Jul 25, 2013
14
The reason I want this setup is mainly so I can have a fan on my trans cooler so I can get air flowing through at the pits when hot lapping. Ever since this s475 my trans is much much hotter (200*+). I thought the mishimoto coolers were good quality, I was wrong. Any other ideas out there? I'm okay running on in the stock location as well I just figured it would be better in the bed away from the cooling stack for less condensed heat.
Tomorrow we shall see how the stock cooler does with a little brake cleaner sprayed on after a pass.
Hello Cknight199,
Did the product fail in some way? Can you confirm how large the OEM cooler is? It sounds as if the cooler you installed is smaller than the OEM cooler, thus causing the issue. We are in process of developing and testing larger transmission coolers to help the diesel community upgrade from the stock units.
Feel free to contact me directly at [email protected]. We would be happy to assist you in finding an alternative solution.
Thanks!
-Pat
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
Where are you guys getting these coolers? I'm planning on running 5/8 lines next year. I really like the 2 coolers in the front of the bed. Cutting those holes is weight reduction;)
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
We got ours from the one and only Nick Murdock :). Works great!
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
Hello Cknight199,
Thanks!
-Pat
I don't run mishimoto coolers, but Mike L didn't seem to approve of them and that's enough for me to stay away ;)
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
The one you posted is not big enough, I have one similar and it keeps around 200. Here is mine, but Mishimoto or setrab universal 19, 25, or 30 row oil coolers would work. I am planning on removing my factory coolers and using the bigger one or two of sebtrab or mishimoto cooler.
