ARP's & Head Gaskets, oppinions appreciated
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Its not a big deal swinging the condenser out of the way, just bend it slowly/carefully/no more than you have to. ;)
custom8726
2,784
Upstate N.Y
I was looking at that today, seems like theres enough room/slack were I can leave the A.C. unit intact without cracking any of the lines. I really dont think the motor is going to be all that hard to remove after looking things over today, Atleast I hope so. I figure 4-6 hrs to get it out of the truck with 2 guys?? Guess I will know how much I underestimated it this weekend;):)
Krazykid
<-Daily Thought Process
Nov 22, 2008
247
Upstate, SC
Ben did a really nice write up on how tro remove an engine. Let us know how things go this weekend.
custom8726
2,784
Upstate N.Y
I got all my parts ordered today and will be pulling the motor over the weekend. I am still looking for suggestions on whats needed or helpfull to do while the motor is out pertaining to an up coming twin install? Should I buy & install an EGR delete kit now or wait untill I do the twins?? I read something about an oil tap:confused: I am thinking april or may before I get the $$ for the twins but I would like to make my life easier down the road if possible.:)
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I would def tap the upper pan if it us off
and I would install a egr delete so you don't need to reinstall
if you run a lb7 uppipe then you just need to bluild aplate for the egr motor and then just swap your heater hose
maine04max
Dec 11, 2008
1,009
Drain line:
also will need a 37/64 drill bit, a right angle drill (small) and a 3/8npt tap
555 100128 - Blue 45 deg Flare Fitting 3/8" NPT to 45 deg -10AN flare
555 100053 - Straight Push-Loc Hose End -10AN
555 102030 - Push-Loc Hose Black -10AN 5 ft
i used approx 3.5 ft of the drain line, if i were to do it again i would probably go with braided line for this too but the rubber seems to be working great so far and doesn't destory everything it rubs against.
Jason above is a list from Mainers diy twin list , as Simon said tap your oil pan while its out to save you some hassle
maine04max
Dec 11, 2008
1,009
there is a flat spot in the upper oil pan on pass side near the back iirc ....... btw i just ordered my parts from that list on the jegs site
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Thanks :hug: Does it matter were I tap the pan?
here is a decent pic of were you tap . from were i have it , i would move it out a 1/2"-1/4 " or so , mine works fine but it is pretty close to the starter
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Drain line:
What is the reason to swedge down to 3/8"?
custom8726
2,784
Upstate N.Y
Update, Motors out and went pretty smooth other then a couple broken parts:(:) Only took the 2 of us 3hrs to get it out of the truck, then another couple to pull her apart. Heading to the engine/machine shop first thing in the A.M.:)
custom8726
2,784
Upstate N.Y
Motor is at the machine/motor shop and apparently will be getting some SoCal part's for the heads. Everything else looked to be in good shape thus far:thumb:pistons are getting machined tomorrow aswell as keying the cam/ crank, carillo's, etc,,, final balancing should be done around tuesday and hopefully back in the truck next wed/thurs with a little luck.:) I Also checked out your motor while I was there Craig, looks pretty sweet, Only problem I seen, Is now I want a SoCal Cam aswell:(:D:thumb:
maine04max
Dec 11, 2008
1,009
you might as well add a cam hile your in there :rofl::rofl::rofl: whats being done to the heads?
custom8726
2,784
Upstate N.Y
How about you just let me borrow your's:D The heads are just getting cleaned up a bit, mostly the exhaust ports with SoCal springs and retainer's.. I Was not planning on it, but like you said, "While your in there":rolleyes::)
