ARP's & Head Gaskets, oppinions appreciated
custom8726
2,784
Upstate N.Y
If you are not touching the heads just go with C's thats what I did and you cant really tell aiffrence
I am hoping I do not have to touch the heads, as that would require me to ship them and increase down time significantly..
While I have you guy's (& Gal's) attention, What else should I do while the motor is out to make my twin install easier? I planned on doing MPI twins this month but it's going to have to wait another month or 2 untill I get the engine strait. Unless it's a huge differance in install time for the twins with the motor out?? If so I could make it happen this month If I have to:D
Krazykid
<-Daily Thought Process
Nov 22, 2008
247
Upstate, SC
This must be nice.......I would love to say I'm ready for twins......Not going to happen this year with the news of Head gaskets going out! Just want the truck running correctly again......I think I have a bad CP3 as well....
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
C's are the thickest
You can put what was already on there.
If you are running a big tune it wont hurt to drop the compression a bit
the C's will drop your compression a little bit but you cant tell
Kevin your advice is great but if you do a seach on head gasket thickness you will find your info is not 100%;)
It is recomended that you straiten the heads......there are options though:)
Best of luck!
kman2468
Old Man Truck
May 3, 2009
374
33
I would not lose any sleep over it;) I have been running the sh!t out of my 05 for the last 2 year's at 500+ WHP and this is the first engine problem I have had.
i wont loose sleep lol but it still worries me
i just did my MP after 125k miles and my truck overheated once in temp at 115 towing up hills
i cant believe they didnt blow then
2,007
Im pretty sure using feeler gauges with a decent straightedge laid diagonally across the head will help you figure out any head warpage. I know it'd be a PITA to do, and am not sure just how far you want to go, but since the engine is already out, Id look into getting the cam and crank keyed and the pistons delipped.
Its funny how once you get the motor out, all these things you could or should do suddenly rear their ugly heads. Its not all that hard to spend $5k on a "basic" Dmax build before gaskets, let alone how quickly $10k can be spent. Sheesh. Good luck with whatever you choose to do...it is a nice learning experience tearing one of these engines down.
Simon, I didnt realize LLYs had any more of an issue with HGs than any other Dmax model.
Krazykid
Nov 22, 2008
247
Upstate, SC
I'm not really looking to go much futher with the engine build just fix what's broken at this point. I wish I could add twins, etc. Just don't have the $$$$$.
custom8726
2,784
Upstate N.Y
I am weighing out my option's right now, but a set of Rod's and keyed cam/crank would be nice:) Really depends on how quick I can get it done, If its going to be a month, or 2 month process, I am going to just buy another motor for the time being.
custom8726
2,784
Upstate N.Y
Ok, I found a semi-local builder thanks to Main04max :hug:... So I decided to pass on the second motor since the builder told me he could get my long block back to me within a week:thumb: I do have a couple questions since this is still going to be a budget build. The plan right now is to install carrilo Rod's, De-lip my current pistons, key the cam & Crank, Install standard ARP head studs, clean,mill,etc, heads as needed.. My questions are, how crucial is it to de-lip the pistons when my goal is to be around 700WHP with twins? Also how crucial is it to have the rotating assembly balanced? Should I be looking at main studs aswell? Any other usefull info would be appreciated as I plan on having him order my parts tomorrow (3/12/10) and dropping my motor off to him this weekend. Any little tricks to save me some time pulling the motor would also be appreciated.
ripmf666
15,123
14
47
Wentzville Mo
Just me I'm not running main studs. Also save some and run crower rods. My pistons are cut and deliped and coated I'm running at 0 deck height and running c head gaskets and STD arp studs. My motor is balanced also.
custom8726
2,784
Upstate N.Y
Ok, So I need not worry about the main studs, but should get my rotating assembly balanced? The builder said it was an additional $600.00 to balance everything, sound about right?:confused: I already purchased the STD, ARP studs last week so that's a definete. What is the point of cutting the pistons and not just the lip? I want to keep my compression pretty close to stock. Thanks for the info thus far :hug:
custom8726
2,784
Upstate N.Y
Someone needs to ask Guy about that. I know I paid less for my crowers if anything the carillos would be more.
My builder qouted me less ^^ but I did review Guy's site and the Howards were the only ones that were more expensive. Regardless the builder recomended carillos from his previous experience, and I have heard alot of good things about them on this and other boards, so I guess thats the route I am going unless there is a substantial differance in price????
ripmf666
15,123
14
47
Wentzville Mo
My balance job cost around 500.00 was done up in NY on the border of Canada by a shop that does alot of big trucks and race motors had another 175 in shipping. I know some shops are cheaper but after shipping it adds up to the same. I went from 16.5 to 1 to 16 to 1 now
maine04max
Dec 11, 2008
1,009
Jason . im glad you were able to work things out :thumb:
after seeing Tom's info on his tear down (crank walk) I would think about main studs
custom8726
2,784
Upstate N.Y
And that is accomplished by,,, the heads being milled, the H.G. thickness, the pistons being cut, or all of the above?? Is it nessary to mess with compression with expected power levels in the mid 6's to 7ooWHP??
