got a text from him last night that it works after i told him to re check all his connections. he had a bad switch (assuming brake pedal)
It was the momentary switch.
I also lost reverse.
This seems like a neat piece Ben!
Any other LMMs running one successfully? I may be interested for my truck here shortly.
Once I got the controller hooked up it works great. If you use it a few times while driving you will lose reverse. No codes or CEL, once you turn your truck off and restart you will have reverse back.
Anthony what are the exact conditions that you lose reverse?
IE, is it if you force-lock it and then go back to "normal" factory mode a bunch of times in rapid succession??
If you do a mock 1/4 mile run, boosted 4wd launch, force-lock the converter out of the hole, run the 1/4 mile, and at the end of the 1/4 mile either hit the brakes or press the button again to return to factory....does it lose reverse?
Or only after multiple times?
Im wondering if this is something in the LMM TCM operating systems? All the other 6-speeds have not reported any problems. What TCM OS# are you running? Does anyone know off hand how many different LMM TCM OS #'s there are?
i know he was working on a trans all day yesterday, but to make you feel better, he hasn't responded to me either recently
After the videos from Florida I can understand why :roflmao:
